12-04-2017, 05:20 PM | #1 |
ijaz429
12
Rep 26
Tire pressure after tire swap
i recently replaced the OEM run-flat high-performance summer tires with conti extremecontact dws 06 non-run-flat all-season tires on my 20" wheels. the tires are the exact same size but obviously a different type. my question is, do i keep the same tire pressure recommended on the door sill?
12-04-2017, 05:31 PM | #3 | |
Rep 2,388
that been said i always go higher with 275/315 combo - I go up to 44psi (a bit better handling and a bit better mpg and no need to pump it up during cold months when in the morning you'll have a good 4-5psi lower readings) but that's just me |
12-04-2017, 06:18 PM | #4 | |
Rep 525
DuSh2113.50 |
12-05-2017, 09:22 AM | #5 |
Rep 1,066
Drives: 2015 X5 50i M Sport
The same here. I do 40F / 44R on winter months to avoid the low readings.
2019 Cayenne Turbo
DuSh2113.50 |
