12-08-2017, 09:35 AM | #1 |
Rep 18
OBD2 Tuning of F15 X5
Came across this post yesterday and thought it might be of interest to the community. I am unaware of any other OBD2 tunes for our cars. Very exciting stuff!
For those unfamiliar, brentuning is an extremely reputable tuner for just about anything with 4 wheels. See their description and comments in the image. Instagram link here: https://instagram.com/p/BcaK8JFF2xu/ |
12-09-2017, 02:29 AM | #2 | |
Rep 46
12-09-2017, 12:30 PM | #4 |
Rep 2,388
12-09-2017, 12:44 PM | #5 | |
Rep 1,388
12-10-2017, 03:11 PM | #6 | ||
Rep 826
Drives: 2017 C43 AMG
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
DuSh2113.50 |
12-10-2017, 03:43 PM | #7 |
Rep 992
Biggest question is... I assume this tune would be detectable if taken in for service? Also, if stock tune is reloaded are there still "tracks" left that a tune was on the car? When I flash my ford ecu/pcm it resets the KOER (key on engine running) count, which obviously is a red flag to dealer.
12-10-2017, 04:21 PM | #8 |
Rep 2,388
12-10-2017, 04:38 PM | #9 | |
Rep 826
12-10-2017, 08:44 PM | #11 |
Rep 992
I'm not worried, because I've decided that I don't want to do either. It runs great the way it is. I was just interested in how it works on the bmw. I am familiar with the ford pcm, just not the bmw's.
12-10-2017, 10:28 PM | #12 | ||
Rep 1,066
Drives: 2015 X5 50i M Sport
2019 Cayenne Turbo
DuSh2113.50 |
12-11-2017, 09:51 AM | #13 | |
Rep 18
Also, very interesting timing that VF and Bren Tuning both released F series ECU tuning info within 24 hours of each other. Is this strictly a timing coincidence? OR did a 3rd party finally crack the ECU and now all the tuners are throwing their tunes in? I'm genuinely curious how that worked out. Silververtu I'm new to the forum and just saw your signature. We have a (reasonably) similar car lineup. I own a 987 Cayman S and an F15 35d. The X5 and Cayman are both fabulous cars, the best of both worlds. Cheers! Last edited by Mitch567; 12-11-2017 at 10:03 AM.. |
12-11-2017, 10:53 AM | #14 | |
Rep 2,388
12-11-2017, 12:03 PM | #15 |
Rep 1,066
It's the small/nimble vs. big/muscular power car.
2019 Cayenne Turbo
12-11-2017, 05:37 PM | #16 | |
Rep 299
DuSh2113.50 |
12-13-2017, 07:05 AM | #17 | |
Rep 826
12-13-2017, 11:36 PM | #18 |
Rep 2,388
So since we didn't get an answer, I'll try to fill the void: as per other tuners Stage 1 is about 100hp and Stage 2 is about 120hp gain. So difference is only 20hp or so.
Which raises a legitimate question - why the hell should we suffer smell from catless DPs for just a mere 20hp difference (Stage 2 requires DPs)? Another thing to consider is that all tuners give different numbers, some tuners Stage 1 is more than others Stage 2 - at least on numbers, which I think may be a BS. The things are more complicated because not many tuners properly disclose on exactly what dyno their charts are made. This is important as DynoDynamics is tougher dyno (shows less) than Mustang dyno - which in turn show less than Dynojet (btw most tuners use Dynojet in their graphs and sheets and results look a lot better than they are on let's say DynoDynamics dyno) I can go on and on, but IMHO there should be a common denominator to all this tunes so that we can know what we are paying money for. $1300 to $1900 is not cheap. especially given that it's usually just a over the counter tunes that they sell in bulk and especially now that no more DME drilling is required - they can just sent us a file that we can upload via OBDII in under 10 min IMHO amount of max boost in bar or psi should be one of the specs to look for in a tune - it gives you a some idea (not complete as other things are at play) of what a tune is capable of. For example I'm flashed with Stage 1 tune and I want to know if going with Stage 2 will be beneficial and I don't want to end up with less power - which is possible depending on tune. Enough of my rant, but what I'm trying to say is that tuners need to be more open to public, they need to work with us if they want new clients and money. We need to be able to get all the answers - which we clearly did not in this thread. It's not VF-Engineering fault, almost all tuners on my experience are like that: they disappear when you asked a question. I understand they are busy, but this is the only way for them to get money - they have to understand it and work with us - otherwise people won't do it - there's too much troubles to begin with, very few will decide to have a tune on expensive car that costs $50k used Last edited by DuSh; 12-14-2017 at 07:51 AM.. |
12-14-2017, 10:42 AM | #19 |
Rep 18
12-20-2017, 06:40 PM | #20 | |
Rep 525
12-20-2017, 06:59 PM | #21 |
Rep 826
what tuners specifically?
