09-28-2015, 02:04 PM | #1 |
M Performance
673
Rep 755
X5M brakes on X5 M50d
Hello,
I asked about this some time ago and have now been working on it further. So my car (collecting it Weds) has the upgraded M Performance brakes fitted as of today. I took the chance to go try the X5M rotors on the vehicle and it would appear... Front will fit fine Rear won't fit without a hole being drilled for the locating screw. The hole on the X5 rotor is in between the 2 bolt holes. On the X5M rotor there are 2 holes for this, but both are offset towards the bolt holes slightly. So my plan is to machine the hole. Anyone else been down this route? Thanks Mat
F90 M5 Frozen Dark Silver Ultimate
G80 X Riviera Blue w/ Kyalami Carbon Ultimate G05 30d Mineral White Instagram - @matfireworks |
09-28-2015, 02:17 PM | #2 |
Rep 8,774
Perfect timing.
So you confirmed that the X5M front rotors fits the M Performance brake kit correct? I am doing the same install tomorrow for my X5 except I am keeping the MPBK rear rotors and only using the X5M front rotors. Alan
09-28-2015, 02:20 PM | #3 |
M Performance
673
Rep 755
Alan
Not be offering the fit to the car but they appear to be identical side by side. I would be interested to hear how you get on. Unfortunately when I got there the front was done so could not try. Please let me know how you get on. Thanks Mat |
09-28-2015, 02:39 PM | #4 |
Rep 8,774
I will bring both sets of rotors to my installer tomorrow so just incase the F85 front rotors don't work I will have a back up plan. Everything i've read suggest that they fit since they are the same size as the previous Gen X5M
Alan
09-28-2015, 03:50 PM | #6 |
Rep 525
im still contemplating the X5M rotors for my MPBK.... havent decided as of yet...i like the drilled look very much, but wondering if its really worth it to go for drilled front and rear.
09-28-2015, 05:26 PM | #7 |
Rep 18,628
Guys, in my experience, you can skip the screw since the brake rotor will be sandwiched between the wheel and the hub anyway. Some European car don't use a screw to secure the rotor to the hub itself. I forgot which European brand, if I remember correctly, it is Benz and Porsche.
I would put an extra 3-5lbs of torque on the lug bolt.
1230vani637.00 |
09-29-2015, 01:19 PM | #8 |
Rep 8,774
My installer just texted me saying that the front F85 M rotors bolts right up no issues. Can't wait to pick up the X5 after work!
Alan
09-29-2015, 01:37 PM | #9 | |
Rep 710
And do not over tighten the lug bolts - you can start to warp rotors as EURO rotor metal is a different alloy than most - that's why you have to replace much sooner than US machines. The rotor and pads work together to stop the car rather than US rotors are there to take punishment from pads only. But its cheaper to replace pads than pads AND rotors. Anyway, torque to spec ONLY.
09-29-2015, 01:56 PM | #11 |
Rep 8,774
Cheapest place I've seen online is from a BMW dealer on ebay $2499 with free shipping for the full M Performance brake kit.
Alan
09-30-2015, 07:52 AM | #12 | |
Rep 8,774
Part number is 34111123072 (you need two of these) Alan
10-01-2015, 08:16 AM | #13 | |
M Performance
673
Rep 755
Mat
10-20-2015, 10:32 AM | #14 |
Rep 53
Thanks to Alan giving me the right input and all needed details! :thumbs:
Finally the installation of the X5 M F85 brake discs on the M Performance brake of my X5 50i (AC Schnitzer ACS5) was successful. The front rotors fit without any modification (only shorter fixation screw) and for the back rotors I milled a new hole with a step for the screw head on the right position. I used the M performance brake rotor as reference. The holes on the F85 rear rotor are not on the right place for the X15 brake holder. Here the final pictures in combination with my winter tires. |
10-20-2015, 10:33 AM | #15 |
M Performance
673
Rep 755
Nice My discs and screws arrived yesterday (long lead time) and I will be doing exactly the same.
10-20-2015, 10:49 AM | #16 |
Rep 8,774
Looking good. Don't forget that coding is REQUIRED if you want the full benefits of the MPBK. I am still amazed just how much better the brakes feel with this upgrade.
Alan
10-20-2015, 11:03 AM | #17 | |
Rep 53
You are right. I did it already! In Germany you will got only the approval for the kit in your documents with a declaration of the dealer that he has done the coding for the MPBK. |
10-20-2015, 09:57 PM | #19 |
Rep 55
Just wonder what needs to be coded after installing the brake kit? I think my shop just installed it without coding 😨
10-21-2015, 07:28 AM | #20 |
Rep 8,774
BMW specifies in the MPBK install that coding is required. I posted about this in the coding thead of what needs to be done. The brake pedal feel difference was dramatic before and after coding for the MPBK. Others on the 2/3 series forums reported the same feel change before and after coding for it.
Alan
10-21-2015, 08:26 PM | #21 | |
Rep 55
Thank you Alan, found it on the coding thread.. hah i guess it will take a while for me to understand the whole coding thing before coding the MPBK into my car |
11-15-2015, 04:36 AM | #22 | ||
Rep 72
