      04-15-2018, 10:59 AM   #45
AlpineOnCoral
Drives: 2018 X6 SDrive35i
Originally Posted by CatalinP View Post
For F15 set the following to "Aktiv":
BDC Body -- V_MAX_AKTIVER_EINSTIEG_AKTIV
BDC Body -- V_MAX_DEAKTIVIER_EINSTIEG_AKTIV
Then check that the following have: wert_01 = 00 00
BDC Body -- V_MAX_AKTIVIERUNG_EINSTIEG
Is that thru BimmerCode? If so, do I need to be in expert mode? Thanks!
2018 X6 SDrive35i Alpine White on Coral Red
M Sport Package, MPPK
      04-15-2018, 11:04 AM   #46
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Yes and yes.
      04-15-2018, 11:04 AM   #47
mkdan2004
Drives: BMW X5 F15
You can code it using bimmercode in which case, yes, you need to use expert mode.
      04-16-2018, 03:48 AM   #48
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Interesting. I did not code either of those. I coded EINSTIEGSHILFE_AKTIV in BDC.
iconoclast7265.50
      02-24-2019, 12:01 PM   #49
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
hey catalina, just wanted to confirm was this to "deactive" the steering column from moving upon easy exit/entry? seems counter intuitive if it is given you're setting these to active...
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      02-24-2019, 01:14 PM   #50
CatalinP
Yes, you set those to active in order to disable that function.
Maverik2594140.00
      03-27-2019, 03:57 PM   #51
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
so oddly enough i did this and now it still adjusts. but this time it doesn't remember my preferred setting via the key. So it just resets to full stowed position upon shut off and then stays there when i come back to the car...grrrugh fixed it last night. Apparently one of the lines of code didn't go through. I hate my Wifi adapter. It constantly times out and disconnects me from BimmerCode. I bout a new one last night.
'06 C55 AMG (sold)
      04-21-2019, 08:20 PM   #52
brevets10000
Drives: F15 2015
Thanks - never been a big fan of this feature and coded off tonight using this ^^
      04-22-2019, 12:24 PM   #53
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
Sorry I'm confused...
Like the OP, the goal is to code easy entry/exit (seat slides back) since its not available.
I'm interested in coding this as well, I have been in many cars and surprised BMW X5 doesn't offer this feature
Is the code above to enable or disable? I have bimmercode, can anyone assist on what to code in expert mode?
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
      04-22-2019, 12:37 PM   #54
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
I recently had some coding done on my 2018 X5M and the seat no longer retracts for "Easy Exit"... We tried the coding in this thread and it doesn't work and disables the steering wheel from retracting as well as the seat. Both remain static. Anyone on here have any ideas or suggestions on how to code this back into my vehicle?
      04-22-2019, 12:39 PM   #55
CatalinP
The above coding DISABLES the steering column movement for easy entry / exit. Nothing to do with the seat.
iconoclast7265.50
      04-22-2019, 12:41 PM   #56
iconoclast
iconoclast's Avatar
7266
Thank you for clarifying. Do you or anyone on here have steps on how to code back the easy entry/exit for the seat?
      04-22-2019, 12:45 PM   #57
CatalinP
First 2 lines in reverse...
iconoclast7265.50
      04-22-2019, 05:49 PM   #58
iconoclast
iconoclast's Avatar
7266
No luck. Not sure why I am having difficulty with this but does anyone on here have step by step instructions on how to code the easy entry/exit seat back on?
      04-22-2019, 08:49 PM   #59
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
This may be redundant but is it in the cheat sheet how to code off? May just do that in reverse
'06 C55 AMG (sold)
iconoclast7265.50
      04-22-2019, 08:57 PM   #60
iconoclast
iconoclast's Avatar
7266
Tried but no luck... Not sure if there is a conflict or just doing something wrong.
Maverik2594140.00
      04-22-2019, 09:04 PM   #61
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Can you load from a previous save? I never save my set codings but I know many do.
'06 C55 AMG (sold)
iconoclast7265.50
      04-22-2019, 09:15 PM   #62
iconoclast
iconoclast's Avatar
7266
I do not think there is a saved file of original coding before the new changes were made but I will ask. If there are I will post.
      04-25-2019, 10:39 PM   #63
Almaretto
Almaretto's Avatar
2374
https://f80.bimmerpost.com/forums/sh...3&postcount=30
  • BDC_Body: EINSTIEGSHILFE_AKTIV
  • SM: EINAUSSTIEGSHILFE
  • SM: EAH_VERFAHRWEG_SLV_PHYS
  • SM: EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS
iconoclast7265.50
      04-26-2019, 07:24 AM   #64
iconoclast
iconoclast's Avatar
7266
THANK YOU!
      04-26-2019, 11:12 PM   #65
Almaretto
Almaretto's Avatar
2374
THANK YOU!
iconoclast7265.50
      04-30-2019, 11:08 PM   #66
Neuera09
Drives: 2016 X5 Xline with MPPK
Couldn't get mine to work.
What werte value did u use for the EINSTIEGSHILFE_AKTIV module once you make it active?
Also when I change the default values for the two EAH modules, the system changes initwert to UNKNOWN.
