03-12-2018, 01:36 PM | #2 | |
11827
Rep 15,400
The more reps you collect, the more it goes to the right and turns red. They're trying to tell the popular kids they're cool while making others blue.
03-12-2018, 02:40 PM | #3 |
Private2
2999
Rep 49
Drives: BMW M3 F32 Coupe!
If it's around the middle, your rep score is around the average, if it's more to the right of middle your score is above average and more to the left you are below average.
Test 23456rt
03-12-2018, 02:41 PM | #4 |
Private2
2999
Rep 49
Everyone is blue on the app
Test 23456rt
03-12-2018, 02:48 PM | #5 | |
11827
Rep 15,400
I'm working on my reading skills, I missed the app word!
You need to add some colors and then we can do a rerun to this! I tried saying sorry, my bad but I'm allergic to those words.
03-12-2018, 03:00 PM | #7 |
Private2
2999
Rep 49
I exist to test and develop the app. My points are all artificial to test things
Test 23456rt
03-12-2018, 03:07 PM | #8 |
Rep 5,993
03-12-2018, 03:12 PM | #9 |
European Editor
10539
Rep 22,992
Rep Points...
Just cross posting this for the next person to ask why their rep points have gone down or are fluctuating from day to day.
Loss of Rep Points... http://www.1addicts.com/forums/showthread.php?t=1472480 Dackel
///M Power-Belgium63319.00 |
03-13-2018, 04:20 PM | #11 | |
Rep 1,637
Btw you are app developer or BMW enthusiasm or both sir? |
03-13-2018, 09:59 PM | #13 |
Private2
2999
Rep 49
Test
Test 23456rt
03-14-2018, 11:57 AM | #14 |
Rep 677
The Bar is Showing Standard Deviations
OP, The bar is showing actual standard deviations (SD). Light Blue if you are <1 SD, Dark Blue if you are <2 (SD), Red if you are <3 (SD). Obviously if the bar is full with all three colors than you get the >3 standard deviations note.
In statistics, the standard deviation (SD, also represented by the Greek letter sigma σ or the Latin letter s) is a measure that is used to quantify the amount of variation or dispersion of a set of data values. Think of a bell curve used on a chart to represent data, the target is the peak of the bell. In some cases, like a high volume production line, you want to hit the peak or target every time. Anything higher or lower means a defect in your product. "All variance is evil". Companies would react to the quality indicator and take action to get back on target by changing out wearable items in the production line equipment, or change a tool, process, etc. So, if your production line of animal crackers is running on a six sigma level (meaning you can go -3/+3 (SD) from target, you would have some absurdly low error rate for every 1 million crackers made. In Bimmerpost's usage they are taking the whole population's average and setting the peak at the start of the curve to score how many standard deviations away in a positive direction from the average you are. (using a half bell curve, since you can't go negative with rep points). It would be interesting to see the shape of the Bimmerpost bell, which I presume changes with membership numbers, and I would imagine changes the area value (or percentage) of an actual standard deviation. I think.... Here is an example of a bell curve used with standard deviations, to give you an idea of what I am on about. I hope it helped you along with what others are saying.
F80 ///M3 LCI SSII Lick the lollipop of mediocrity once and you suck forever. |
03-14-2018, 02:07 PM | #15 | |
Rep 5,993
03-15-2018, 02:43 PM | #16 |
Rep 677
Maybe It's Even More Complicated
I am inclined to think it is even more complicated in this case. You yourself have a rating that is more than 1 standard deviation, which according to the Bimmerpost formula is in the top 15% of the population. Since Reputation points are measured in a positive direction only (no negative Rep points), the software ignores the possibility of a negative score, yet tells you where you lie in a standard deviation on a bell curve that includes the possibility of a negative score.
I am sure one of the moderators can better explain the whole thing and in simpler terms.
03-15-2018, 08:06 PM | #17 | |
Administrator
6724
Rep 4,201
The other thing is you assume that a bell curve or any population distribution needs negative numbers and so a half bell is used? You don't need negative values to create a population curve. We simply do not display the negative SDs to people since it would not be as informative due to our non standard population distribution. In the end its almost to the T how you explained it in the first post except we have some tweaks to account for our population distribution and we also take into account relative activity (surfing, etc..) |
DBACE689.00 |
03-15-2018, 08:42 PM | #19 | ||
Rep 677
And there it is....
03-15-2018, 08:48 PM | #20 |
Rep 677
Depends on the Application you Use
This bar right here........you see it in a web browser, but not on the IOS Application for Bimmerpost.
IK6SPEED4488.00 |
03-15-2018, 09:16 PM | #22 |
Private2
2999
Rep 49
The blue bar is in the app, its right under your username in the left hand menu pane
The colored bar (blue to red) is on the web forum
Test 23456rt
Ultimateone172.50 DBACE689.00 |
