03-29-2018, 09:13 AM | #1 |
Rep 638
Updated BMW Connected app is useful now
BMW just updated the Connected app today. Biggest part is sending destinations straight from Apple Maps or Google Maps to the car (vs using the Connected app itself). While it doesn't send the route directions if you do it in Google Maps (the car still does the route), it is significantly better in my opinion since most people search in Google Maps.
I verified it this AM on my way to work and didn't have issues. You can send it as a message to the car, or it'll pull it if you are plugged in. What's New Mar 28, 2018 Version 8.0.1 Thanks to your feedback, this version includes: Send destinations straight to your BMW from Apple Maps or Google Maps See your vehicles approximate drivable range on the Destinations map Service alerts now available for more vehicle models Register your BMW WiFi Hotspot in the app (for equipped vehicles) Helpful explanations for learned destinations Country support for Thailand Updated Privacy Policy and Terms of Use (compliant with GDPR in Europe) Plus, for BMW i vehicles: View detailed efficiency statistics, including comparison data from other BMW i drivers Read tutorials on how to maximize driving efficiency See charging station vacancy when searching for stations Receive a notification on the Activity tab when charging is interrupted
03-29-2018, 11:36 AM | #2 |
Rep 95
Just to clarify, if you select a Google route which is based on traffic jam info for example, the car will re-route it again using its own algorithm?
F85 X5M
911-50th Jeep Abarth 595 Comp Golf Clipper |
03-29-2018, 12:24 PM | #3 |
Rep 638
I don't think it will let you send the route. Only the location of the place you want to go.
03-30-2018, 11:08 PM | #7 |
Rep 2,858
How does the Connected app know which car to send it too? As I have two 2018 M's, F83 & F85? To make matters even more confusing I have two phones.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
03-30-2018, 11:46 PM | #8 |
Rep 900
I hope this update is not the root cause of my BMW Online connection outage the last few days. I can't do any updates and nothing shows in the maps split screen - weather, clock, etc.
04-23-2018, 01:04 PM | #9 |
Rep 473
What MY vehicles does the app work with?
DR CHUCK
2009 E92 M3 Le Mans Blau on Schwartz. DCT. RAC RG63, KW V3, Eisenmann Race, AP Racing, Vorsteiner GTS5 Front Bumper, Vorsteiner GTS-V Rear Diffuser. |
04-23-2018, 09:42 PM | #11 |
Rep 7,160
You select the car in the app. I had two cars in there when I connected my phone to a loaner. It showed my F15 and the X3 I was borrowing.
'06 C55 AMG (sold) ?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wifes now) |
04-25-2018, 01:51 AM | #12 |
Rep 95
I have not found a way to send a google destination though? Still have to use the connected app for that.
F85 X5M
04-25-2018, 05:12 AM | #13 |
Rep 638
Are you plugged in via usb?
04-25-2018, 08:57 AM | #14 |
Rep 190
Drives: 2020
04-25-2018, 11:13 AM | #15 | |
Rep 15,818
+1. i don't see the option to send destination in the Google app nor Apple Map.
IG:d.violet.m3
04-25-2018, 05:48 PM | #16 |
Rep 638
Get a destination, then hit Share, you should see the Connected as an option. Just select it and you'll get another pop up to send it. You may have to hit 'More' on the pop up and turn on Connected App if you haven't done so already. That's how it works on iOS...
Bluesummer587.50 Maverik2594140.00 |
