04-06-2018, 04:10 AM | #1 |
Rep 101
F15 Harman Kardor Equalizer
Hey Guys, i found below setting from China Dealer and it is quite good for ME. Just want to happy share!
a. Super Bass mode: 100Hz +5 200Hz +4 500Hz +3 1KHz +1 2kHz -1 5kHz -4 10kHz-5 b 3D mode (I am currently using it, you can hear the difference from the 7 logic mode and the normal mode.) 100Hz +4 200Hz -3 500Hz +8 1kHz +9 2kHz -6 5kHz +8 10kHz +4 c Classic music 100Hz ;0 200Hz ;0 500Hz 0 1kHz 0 2kHz 0 5kHz -5 10kHz -6 d Pop Music (Second Choice) 100Hz +4 200Hz +3 500Hz -3 1kHz ;-2 2kHz +1 5kHz ;+3 10kHz +6 |
11
TallGuyX5138.00 Slickrick2211.00 Zagga43.00 Silververtu231.00 BigHurmJr24.00 OFFWHITEX5325.50 F15GorDe261.00 Servord30.00 hlrzr19.50 cncmastr1587.00 RED_Y_1054.00 |
04-06-2018, 09:15 AM | #9 |
Rep 101
04-06-2018, 09:36 AM | #10 |
Rep 783
Sorry guys am I missing something here?
Tried the settings but can only change the basic EQ, treble, bass, fader, and balance. No Super Bass mode, 3D mode, Classic or Pop music mode to the EQ? What am I doing wrong with the Idrive settings?
Old Wheels - X5M50d in Carbon Black
New Wheels - X7M50d in Phytonic Blue |
04-06-2018, 09:38 AM | #11 |
Rep 101
The 3D mode, Classic or Pop music is only a reference name.
04-06-2018, 09:56 AM | #12 |
Rep 783
Ok so what should the bass and treble be set at either side of the EQ settings?
I'm finding the quoted setting in this thread makes the sound dull/muffled? The higher the KHz the clearer the sound and higher the Hz the more bass you get? Probably doing something very stupid
04-06-2018, 11:07 AM | #13 |
Rep 142
Which of the above profiles are you using and with what sort of music?
3D is definitely not muffled. Try setting the normal bass and treble settings to flat/middle then adjust the EQ to the above 3D profile settings and toggle Logic setting to taste. I’ve added a bit of trebble and bass to my taste and music choice but that’s personal preference. |
baubaulu41.00 |
04-06-2018, 12:40 PM | #14 | |
Rep 783
Will look at this over the weekend. Where is the logic setting - do you mean on or off?
04-06-2018, 01:16 PM | #16 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Tried the "3D mode" setting during lunch time and it's quite good although it seems a little hollow for my taste. I have Treble set to 0, +4 on bass and Logic 7 off.
I will try the "Pop music" over the weekend.
2019 Cayenne Turbo
04-06-2018, 01:44 PM | #17 |
Rep 842
This is what I use. I found the vocals were a bit harsh before. Everything is now more flat with emphasis on low end bass.
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
04-06-2018, 01:47 PM | #18 |
Rep 1,066
Thanks for sharing!!!!
2019 Cayenne Turbo
04-10-2018, 01:23 PM | #19 |
Rep 78
Sounds awesome! I had my equalizer set too high almost across the board. It caused the sound to be loud to talk over even at the lowest volume with speed volume incorporated as well.
I could wait to go try it so I left my desk at work to go out to the x5 to make the equalizer changes. It's a good setting for sure. Thanks for sharing!! |
04-15-2018, 01:31 AM | #21 | |
Rep 2,700
04-15-2018, 02:56 AM | #22 | ||
Rep 101
thanks |
