04-08-2018, 02:47 PM | #1 |
M3 ZCP Rocks!
187
Rep 192
Drives: 2016 M3 ZCP\2018 X5 35i
Digital Gauge Cluster - Fuel Levels
So I just got my new 2018 35i a week and a half ago and have only filled it up twice so far but I noticed something kind of off in the way it shows fuel level. I have the digital gauge cluster so this may or may not apply to the standard gauge cluster.
It would appear on the surface that the Distance To Empty does not closely match the actual fuel gauge. See first picture. The DTE shows about a quarter left while the dial shows more than that available. Then when I go to fill up it would appear it is not filling all the way. See second picture. This is after adding over 16 gallons over what was already in the first picture. The DTE shows almost a quarter tank used and 421 DTE. The dial also looks like it may not quite be to the full level. Has anyone else noticed something similar? Maybe I just have a calibration issue? Or maybe my tank is not filling all the way? Any thoughts or opinions are welcome!! |
04-08-2018, 02:54 PM | #2 |
Rep 1,260
It's not a calibration issue, is your interpretation which is wrong. The estimated range is based on your driving style and load on the engine over the last few miles.
04-08-2018, 02:58 PM | #3 |
M3 ZCP Rocks!
187
Rep 192
Definitely a consideration. But if I just filled up the tank shouldn't DTE show max range and fill the bar? It did on the 2015 X5d that I just turned in but it did not have the digital gauge cluster.
04-08-2018, 03:03 PM | #5 |
Rep 225
The fuel level is usually not entirely accurate due to the shape of the fuel tank as they use a floating level sensor to measure how much fuel there is.
You could park your car on an incline somewhere and you'll have a full tank of gas lol
2017 X5 xDrive35i M Sport - Space Gray | Adaptive M | Eibach Pro | H&R Spacers | MPPK | MPE | Autotechnik Gloss Black Dual Slat Kidney Grills | Autotechnik Gloss Black Fender Vents | Leather Knee Pads | Painted Front Reflectors | M50D Trim - Gone Last edited by Jlu88; 04-08-2018 at 03:12 PM.. |
04-09-2018, 02:59 PM | #6 |
Rep 621
When I brim my tank it often doesn't show as full until after a few miles and possibly turning off and on. It seems worse when I try to squeeze in as much fuel as possible. I wondered if it somehow causes a level sensor issue. It used to irritate me but I just live with it now!
04-10-2018, 04:24 PM | #7 |
M3 ZCP Rocks!
187
Rep 192
If anyone with the digital gauge cluster would be willing to post a picture right after they fill up it would be much appreciated.
Thanks in advance!! |
04-10-2018, 04:42 PM | #8 | |
Rep 674
Might be that different grade of fuel gives you some longer range... |
04-11-2018, 05:19 PM | #9 |
Rep 50
I had driven a couple of miles post fill up.
spyderbret187.00 |
04-11-2018, 05:31 PM | #10 |
Rep 674
Wow, is that the 50i? Full tank mileage sucks. A Tesla can do more miles on a single charge
04-11-2018, 05:38 PM | #11 | |
Rep 50
04-11-2018, 05:41 PM | #12 | ||
Rep 674
04-11-2018, 06:31 PM | #13 | |||
Rep 50
04-11-2018, 06:38 PM | #14 | ||||
Rep 674
04-11-2018, 07:04 PM | #15 | |
Self-Deprecating Narcissist
7266
Rep 6,561
from my experience owning different vehicles... if the same car is offered with an eight cylinder or more power motor it usually isn't significantly more mpg... the worst was the 4L Q7. the difference between the 6cyl and the 8cyl was 1mpg but the driving experience was much better with the 4.2L.
04-11-2018, 07:16 PM | #16 | ||
Rep 674
Yup, totally different beast the V8 twin turbo x5. The way that motor lefts the car cant be replicated with the single turbo six cylinder. |
04-11-2018, 07:46 PM | #17 | |
Rep 7,160
04-11-2018, 07:55 PM | #18 | ||
Rep 674
04-11-2018, 11:15 PM | #19 |
Rep 225
Biggest mistake I made was not going for the 50i.
I drive city 95% of the time averaging around 270-300 miles per tank and it seems all the 50is are getting around similar mpg in city driving. Was planning to keep the 35i for a while but definitely having 2nd thoughts...
2017 X5 xDrive35i M Sport - Space Gray | Adaptive M | Eibach Pro | H&R Spacers | MPPK | MPE | Autotechnik Gloss Black Dual Slat Kidney Grills | Autotechnik Gloss Black Fender Vents | Leather Knee Pads | Painted Front Reflectors | M50D Trim - Gone |
sbinshihon684.50 |
04-12-2018, 11:11 AM | #20 |
Rep 50
I somewhat regret not going for the 50i. I initially told the dealer I wanted it and was shellshocked when he talked me out of it. I loaded up on other features instead and I regret none of those.
Looks like Bimmercode has a (new?) option to change the scale of this digital gauge between 20l/100km and 30l/100km. Might have to check that out. I'm not overly concerned about the MPG given it's been cold and used on a lot of short city trips in the most recent readings. A couple of summer road trips will give me a better opportunity to monitor things on that front. For the record, I do not wish I had a Tesla. |
sbinshihon684.50 |
04-12-2018, 01:43 PM | #21 | ||
Rep 493
Its fuel level sensor is capacitive: just two metal plates on opposite sides of the tank and the sensor exploits the different dielectric values of air and gasoline between the plates. Advantage: no moving parts, no holes through tank walls. Disadvantage: the sensor must be calibrated again every time the fuel type (AVGAS 100 LL or car gasoline) is changed, as different fuels have different dielectric values. Calibration is easy: fill to top, push the calibration button, the fuel computer does the rest. I wonder if anybody has access to the tech manual of this BMW model and verify the fuel level sensor system used. |
04-12-2018, 02:20 PM | #22 |
Rep 5,066
I also thought about getting the 50i because honestly fuel concerns aren't much different with the 35i... However... If I went with a 50i which I've built many times and contemplated.. with the options "I want" the price would have been very close to a X5M... So why would I get a 50i when I can just go all out on the X5M?
