04-21-2018, 10:37 AM | #1 |
Rep 1,760
M sport exhaust tips
Hey guys,
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST Last edited by virtualbong; 08-21-2018 at 08:16 PM.. |
04-21-2018, 10:48 AM | #2 |
Rep 714
Drives: BMW X5 M Sport - G05
M exhaust or stock?
04-22-2018, 05:08 AM | #3 |
Rep 648
Drives: 2016 F15, 2015 F83
If it's a 50i with the stock exhaust then no, it is not movable.
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 04-22-2018 at 11:50 AM.. |
04-22-2018, 08:13 AM | #4 |
Rep 714
If it’s the stock exhaust for the M sport, 35i, those tips aren’t adjustable. If someone did the upgrade for you and you have the M Performance Exhaust, those tips are adjustable.
04-22-2018, 06:51 PM | #5 |
Rep 1,760
I have to assume that this is just the stock m sport exhaust that is not adjustable. One interesting thing I noticed was that there is a nice growl at startup and idling but I really don't think it's the M. Is there lie screws to adjust the tips? If so, pretty sure I don't see anything.
04-22-2018, 09:19 PM | #6 | |
Rep 714
04-22-2018, 09:37 PM | #7 | |
Rep 1,760
I'm pretty sure it is not the MPE as I just found a thread talking about how the stock exhaust has a nice rumble at cold start. Thanks Nick for all the good info.
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
04-22-2018, 11:01 PM | #8 |
Rep 1,760
With all this info...is there basically no way to correct the uneven placement of the tips? Is this how it comes from factory?
04-23-2018, 07:49 AM | #9 |
Rep 979
Check and see if your x5 has been accident... maybe it was not repaired properly....
04-23-2018, 08:04 AM | #10 |
Rep 5,066
Have you looked under the the rear to see if the pipes are clamped or one solid piece?
Take a photo and I can tell you right away if it is MPE or not.. If it is MPE then you can adjust the exhaust tips to even it out.
04-23-2018, 01:27 PM | #11 |
Rep 714
No problem! They should be straight if it’s the stock exhaust, unless an accident had occurred as someone else mentioned. It would be easy for the MPE to be crooked. I had to cut the pipe just before the muffler, but luckily I knew what I was doing. Had someone else tried to install and didn’t know what they were doing, cutting that pipe at a slight angle would have caused those tips to be uneven. Considering it was my first time installing, I’d say a little bit of luck came into play. There were no instructions as to where to cut the old exhaust, unfortunately for some I’m sure.
04-23-2018, 08:43 PM | #12 | |
Rep 1,760
I don't think there is nothing I can do because if it was in an accident...it was never reported.
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST Last edited by virtualbong; 04-23-2018 at 08:59 PM.. |
04-23-2018, 08:52 PM | #13 |
Rep 1,201
A lot of things don't get reported to Carfax so you can't trust it 100%.
Why not just bend down to see if the muffler says M performance?
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
04-23-2018, 09:04 PM | #14 |
Rep 1,760
Is this what you need?
04-23-2018, 09:05 PM | #15 |
Rep 1,760
Yeah I didn't see anything so I'm pretty sure it's not. I just read that the muffler looks exactly the same as the stock so I wasn't sure what I was looking for.
04-23-2018, 09:34 PM | #16 |
Rep 714
04-23-2018, 09:42 PM | #17 |
Rep 1,123
Drives: E39 540i, E90 320d,F15 30d
Had a similar issue with our F15, took it to dealership - they align the exhaust tips by adjusting the rear bumper and now it's sitting flush as it should!
04-24-2018, 05:09 AM | #18 |
Rep 1,260
04-24-2018, 07:54 AM | #19 | |
Rep 5,066
See how it is cut and needs to be clamped to the muffler. If there is no clamp on your muffler tips then it is stock. As far as adjusting the stock exhaust I am not sure, but I suspect as LocksmithNick mention earlier it appears that the muffler has been replaced and cut incorrectly at the pipes and is affecting the alignment of the tips. Also considering the over spray noted by LocksmithNick it appears your car had a mishap in the rear section of the X5.
LocksmithNick1142.00 |
04-24-2018, 08:39 AM | #20 |
Rep 714
Seeing as you’re in Boston, it probably got bumped while parallel parked and someone did a quick fix.
04-25-2018, 05:16 PM | #22 |
Rep 1,760
I doubt there is anything that I can do now...I doubt the private dealership would say that they knew about any repairs since carfax doesn't report anything. Overall the car seems like it's in in great condition.
I have a few things I want bmw to look at since it's still under the original warranty so I'll see if they'll fix the alignment. |
