01-12-2015, 01:44 PM | #67 |
Rep 3,990
I can't for the life of me remember if you got a tune chip yet. However, if you do plan on getting a RaceChip for your 35i, let me know, and I'll send you some info on getting a big discount.
And no, I don't rep for any company. I rep for the community .
01-12-2015, 01:55 PM | #68 | |
Rep 7,063
01-12-2015, 02:20 PM | #69 |
Rep 18,715
Taran.J
This just came up to my mind, for the kidney grill, on the bottom 3 tab, do press the middle part. The clip is actually has dual function. The outer is for unlocking the outer chrome ring from the black slats piece, while the middle one is to unlock the center black slats from the bumper. Maybe this can also help Barbja . As for the RaceChip or JB4. To clarify, the BMS has 2 different version. There is Stage 1 and there is JB4 Stage 2. The Stage 1 is the simplest of all, just 2 connector and you are done. While the JB4 Stage 2, it has to be connected to the CAN wires where it can gives you better control on the AFR, Wastegate control, etc. to give you the better power output. I personally don't know much about the RaceChip, but I would guess that the RaceChip falls in between the Stage 1 and JB4 Stage 2 on the performance wise.
01-12-2015, 02:23 PM | #70 | |
Rep 3,990
01-12-2015, 02:29 PM | #71 | |
Rep 18,715
Gain wise, JB4 Stage 2 is more once you do methanol injection. Oh, just to clear this up for the readers. JB4 Stage 2 only available for 35i / N55 motor. For 50i / N63tu motor, BMS only have Stage 1 available. This one I would say neck to neck with RaceChip.
01-12-2015, 02:32 PM | #72 | |
Rep 3,990
01-12-2015, 02:35 PM | #73 | |
Rep 18,715
Even on the Stage 1, there is a way to tweak it, but I usually don't recommend it since we as human, tend to try pushing the limit. There should be some 2/3/4/5/6 series owner that has done it and have a good data on it. But, I would rather jump on the JB4 Stage 2 just to be on the safe side.
01-15-2015, 12:38 AM | #74 |
Rep 7,063
Thanks to Ben I got my grills finally on!!! World of a difference
01-15-2015, 12:40 AM | #75 |
Rep 7,063
Also got my rear iND painted reflectors on as well tonight.
The fronts I have but will have to wait since its a little more intrusive than I would've hoped to change them up.
01-15-2015, 12:48 AM | #76 |
Rep 7,063
Another shot of the reflectors install and how it went along
01-15-2015, 02:44 PM | #77 |
Rep 7,063
Cahnged thread to my build thread. All updates will be posted here as well as official photo and videography.
All have been warned.
01-15-2015, 03:44 PM | #78 |
Rep 1,746
I kind of like red reflectors in the back, but if you wanted all white, you had to go with this. I wish the front reflectors were this easy to remove... I hate the amber reflectors and would swap them for clear reflectors in a heart beat if they were easy to swap. I will probably just tint over them or just plastidip them black.
01-15-2015, 04:11 PM | #79 | |
Rep 7,063
Also agree with you completely on the front reflectors, if somebody can make us vinyl based off our paints I would still pay as much as the actual reflectors since it would save so much time. But I'll have to make time for these since they've been sitting in my garage since I put my order in on the X5
01-15-2015, 04:24 PM | #80 | |
Rep 3,990
01-15-2015, 04:24 PM | #81 | ||
Rep 7,063
01-15-2015, 04:27 PM | #82 |
Rep 3,990
Yeah, he did a great job for the DIY, but it is not that difficult after my friend showed me how he removed mine. I'll get more info when I can. I was going to take pictures and get the info sooner, but I've just been so busy while he's been finishing it up; I haven't been down there in a while to check and ask.
01-15-2015, 04:38 PM | #83 | |
Rep 7,063
01-15-2015, 11:04 PM | #84 | |
Rep 1,746
Last instructions I saw involved removing the wheel and wheel well to replace those small reflectors!
01-15-2015, 11:59 PM | #85 |
Rep 1,181
Will certainly wait for your response, Opasha. I've been checking the sidemarkers out and I just don't see a probable way to remove them by popping them out without damaging the surrounding area. The rears seem like there is more room with which to fit a pry tool.
The fender liner seems to have the plastic push-pin screws, which are very easy/simple to release if they're anything like the ones on my MB. BTW, the Benz DOES require you to remove the liner in order to access the sidemarkers. German engineering right? |
01-16-2015, 12:51 AM | #86 | |
Rep 265
01-16-2015, 10:17 AM | #87 | |
Rep 1,746
01-16-2015, 10:50 AM | #88 | ||
Rep 7,063
