10-19-2015, 12:00 PM | #1827 |
Rep 40,986
10-20-2015, 05:04 AM | #1830 | |
Rep 40,986
10-20-2015, 08:13 PM | #1832 |
Rep 40,986
PM sent.
10-21-2015, 09:11 PM | #1834 |
Rep 40,986
I replied to your same PM.
10-21-2015, 10:01 PM | #1836 |
Rep 40,986
10-21-2015, 10:35 PM | #1837 |
Rep 47
10-21-2015, 10:38 PM | #1838 |
Rep 40,986
10-21-2015, 11:02 PM | #1839 |
Rep 24
Par 1
Any of the coders here know or are willing to look into doing one of the following upgrades:
1. upgrading the idrive UI to the one that is installed on the new 7 series. (as shown in the photos courtesy of user RodDT) 2. press and holding one of the buttons on the FOB instead of press and holding the ParkAssist button, again just like the new 7 series. looking forward to hear from you genius ones Cheers |
10-24-2015, 05:59 PM | #1841 |
Rep 48
Drives: BMW X5(G05) 2019
HBA Active?
Is it possible to code it on F15?
Asia's F15 FA already Remove 5AP and 8S4. I'm coded BDC_BODY=>3073=>LUT_FLC_FORWARDLIGHTING_Y=>F015_mi t_AFS BDC_BODY=>3068 =>FLA_AKTIVIERUNG=>LDS in A or 2 Dosn't work HBA:泣きます: I found this on cheat sheet: 2012-13 (NBT) and 2014 LCI FRM => 3050 => FLA_VERBAUT => aktiv FRM => 3050 => FLA_AUTO_AKTIV => automatisch KAFAS2 => 3050 => FLA_ON_OFF => aktiv HU_NBT => 3000 => HIGH_BEAM_ASSISTANT => aktiv There is no FRM on F15 and I did not find it on BCD_BODY. I think so KAFAS2=> 3050=> GLAREFREE_HIGHBEAM_ENABLED =>On? KAFAS2 => 3050 => FLA_ON_OFF => aktiv(I can select On or Off only) Wirting google translate english. My english is poor... |
10-25-2015, 07:57 AM | #1842 |
Rep 48
Please tell me.
[QUOTE=Hideada;18801603]Is it possible to code it on F15?
>>I think so >>KAFAS2=> 3050=> GLAREFREE_HIGHBEAM_ENABLED =>On? >>KAFAS2 => 3050 => FLA_ON_OFF => aktiv(I can select On or Off only) Please tell me whether the above settings are what made . |
10-31-2015, 04:09 AM | #1843 |
Rep 48
Those who have enabled HBA is , Do you have a 5AC?
Do I need to add a 5AC? |
10-31-2015, 04:45 PM | #1845 |
Rep 132
Finally was able to get the X coded. Many many thanks to a member on here doing this for me! There was no way I was going to be able to do it....I'm computer illiterate! Anyways, the X should have came from the factory with most of the coding options sans the DVD player which would be a safety issue.
11-01-2015, 09:28 AM | #1846 |
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
Shawn, can you pm me all the relevant links por favor?
I'm quite proficient with VCDS (Vag Com) over the past ten years, but this all looks Greek to me. Don't want to jack anything up, so may need help via logmein. |
11-01-2015, 09:36 AM | #1847 | |
Rep 40,986
11-03-2015, 01:43 PM | #1848 |
Rep 247
Drives: 2015 F15 50i, 2016 E89 35is
Can you code the Night Vision to work without the headlights on while driving?
