12-31-2021, 12:07 AM | #464 | |
Rep 2,737
Also be aware that the newer clusters had different Rom chips where you can't lower the milage and the one you buy should be less miles than your current vehicle. |
06-06-2022, 01:41 PM | #466 |
351
Rep 380
Guys, I had the 6wb installed today on my 2017 x5. I previously had 6WA. My coder remotely coded the cluster and it carried all info over. Now, the problem I have is HUD does not work. My car has hud and 6wb has the hud plug which I plugged in. HUD doesn't not show up anymore, and when I go to idrive setting the adjustments do not respond either. Anyone know what I can do? TIA
06-06-2022, 08:23 PM | #468 |
351
Rep 380
No it doesn't at all. When I go into I drive display settings for HUD, it doesn't respond to what I'm adjusting. The coder said he couldn't see option to code HUD. I'm thinking it's not compatible to f15 even though it has hud
06-06-2022, 10:12 PM | #469 | |
Rep 7,165
06-06-2022, 10:17 PM | #470 | ||
351
Rep 380
06-07-2022, 11:26 AM | #472 | ||
Rep 2,526
Then make sure 6WB was VO coded. Make sure this was done: Quote:
06-07-2022, 11:54 AM | #473 | |||
351
Rep 380
06-07-2022, 01:40 PM | #474 |
Rep 2,526
Ouch, I hope you got the cluster form e-bay and can return/get your money back, this sucks.
blackoutF15350.50 |
11-24-2022, 11:24 AM | #477 |
Rep 942
Drives: 2016 BMW X5
Not sure if this was answered previously and based on opasha's guide it seems like the answer is no - but is it necessary to disconnect the battery when swapping clusters?
12-02-2022, 05:45 PM | #479 |
Rep 942
Drives: 2016 BMW X5
Random question, but I purchased a (used) cluster and it is missing the metal mounting clips. Can these be xfered from my old cluster to the new one easily?
12-04-2022, 09:45 AM | #480 |
Rep 942
Drives: 2016 BMW X5
It seems that after I installed the 6WB that pushing the shift knob to the left no longer activates Sport mode as it used to previously when I had the 6WA installed. Has anyone else experienced this? Is there a way to code this back in?
12-06-2022, 11:26 AM | #481 |
Rep 2,526
Not sure which knob on the left you are referring to, modes are switched by the buttons next to the shifter between Sport-Comfort-Eco (and Sport+ if coded).
12-08-2022, 08:36 AM | #482 | |
Rep 7,577
Again, moving the gearshift lever over to the left is the STEPTRONIC transmission feature/function/option which is explained in the owners manual (which can be found using the embedded manual in iDrive, too).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-08-2022 at 03:16 PM.. |
12-08-2022, 09:45 AM | #483 |
Rep 942
Drives: 2016 BMW X5
Ah thank you both for the clarification. Makes sense now.
