08-19-2021, 07:49 PM | #1 |
121
Rep 318
Another Continental DWS tire review
My ’16 X5 M Sport came with DUNLOP SPORT MAXX GT DSST, staggered width size. Surprisingly, I got 36K on them and they still showed 5mm tread remaining. They wore relatively evenly but I suspect it is because I ran the tire pressure on the low side (32/36) to minimize the harshness and noise of the run-flats. Wanting a quieter ride, I found the CONTINENTAL EXTREME CONTACT DWS 06 PLUS on Tire Rack at a very attractive price. Apparently the “plus” indicates a slightly upgraded version of the tire and includes a 560 (!) tire wear rating. Nevertheless the price was right so on went the tires.
I just competed about a 1000 mile road trip, Las Vegas to LA, and would like to share the following opinions: -The tires are quieter than the Dunlop run-flats; -The tires are softer riding than the Dunlop run flats…so much so that I had no hesitation on running higher air pressure values (39/41); -The tires are pliable enough even at higher air pressure that I found myself using the “sport” feature on my M adaptive shocks without any degradation to the ride. With the run-flats, I almost always went “comfort” mode whenever I drove around crappy-road LA. - No detectable tramlining on LA's rain grooved highways (neither did the Dunlops); - The tires, however are not ultra-performance tires, instead they’re all season, but they don’t handle any better or worse than the Dunlop run-flats. This is subjective, however, as when I testing the handling, the X5 was never really pushed or carving any corners at full boil. (Nor would I attempt to test my x5 like a lowered sport sedan nor expect it to come close.) So in conclusion, I would recommend the Continental Extreme Contact as a good non-run flat, all season replacement for normal driving needs. Plus a 560 tread wear rating! First pic shows the 315/35ZR20 Continental profile on the factory 11” rim. Last pic gratuitous shot from road stop-by Eddie World in Yermo, CA.
Test
5
08-20-2021, 11:59 PM | #3 |
Rep 612
I've always been a Michelin person since I had my G35 and then my E90 and loved my AS 3+ tires I had on both of those, and I've been hesitant to switch to the Conti's because I've heard the sidewall is much softer and they don't have the response of the Mich's. Unfortunately Michelin doesn't make anything that I feel is a good compromise between all-season performance and tread life for a daily driven SUV, so I think I'm going to give the Conti's a try next time around.
08-22-2021, 02:05 PM | #4 | |
121
Rep 318
Test
08-25-2021, 11:42 PM | #5 | |
Rep 612
I'm going to give the Contis a try though. Michs always force me to swap to winters earlier than I should need to, so maybe Contis will help balance that out also. |
08-26-2021, 02:08 AM | #6 | |
Insta~ f10_sapphire
158
Rep 412
Insta ~ f10_shapphire
08-27-2021, 03:59 PM | #7 |
121
Rep 318
I don’t have experience with the Bridgestones on your X5 so I can’t compare. My research was based on reviews onTireRack website and other users on this forum. Almost all the reviews like the Conti DWS for their comfort, quiet ride, all season capability, affordability, but some comment that they’re a little lacking in “handling”, most likely due to the soft sidewalls (compared to a RFT). It’s my opinion that “handling” is relative and subjective. I use my X5 as a utility and family hauler. While I have M Adaptive Suspension (electronic shocks) I don’t have the Dynamic Handling Package (pneumatic sway bars) which would greatly affect handling (flatter) so I’m never really able to press my X5 to sharp handling. It will never handle as well as some BMW sport. That said, the Continentals do have a (relative) quick steering response but the handling is quickly degraded partly due to the relative soft sidewalls but mostly because of my chassis set up. If you have the Dynamic Handing Package option (lucky you) and intend to upgrade your shocks and springs, then IMO you can improve the handling a bit but only within the limits of a SUV.
Test
08-27-2021, 04:11 PM | #8 |
121
Rep 318
I'm not sure if any "all season" tire is optimized for your area (Minn, I assume). That being said, if I had DHP I would jump on some Michelin Sport Plus, buys some tire cables, and enjoy them until the winter comes. Carve them roads
Test
08-31-2021, 03:58 PM | #9 | |
Rep 93
I have the OE Pilot run flats and love the fat tire look from the back. Some have said the conti seem to look narrow |
09-01-2021, 12:55 PM | #11 |
121
Rep 318
Dunlop vs Conti width?
I don't have a side by side comparison of the Dunlop and the new Contis. I checked Tire rack and they list both tires with the same sectional width, 12.6 in, and the tread width at 10.9in for the Conti and 11.5in for the Dunlop RFT. I can't notice any difference and I suspect that any tire on the 11 inch OEM 469M rim will be reasonably stretched so the perception of "fat" (i.e. bulging" sidewalls) would be not apparent in the profile. The tread width does make its width known. Quick pictures show my rears at 40psi on OEM wheels with15mm spacers. IMO doesn't look "fat" but looks does look wide from the rear.
Test
09-05-2021, 06:19 PM | #15 |
107
Rep 382
I have the continental DWS tires that are staggered.
My right rear tire seems to flat spot overnight and I get a pretty decent wobble for the first few miles. Wondered at first because the car has 39,000 miles if it was an issue other than the tires but after driving a short distance it goes away. |
09-07-2021, 10:18 AM | #16 |
Rep 1,261
09-08-2021, 02:00 PM | #18 | |
Rep 264
Just curious if you speak from experience?
2015 F15 XDrive 50i MSport
