06-07-2023, 11:26 AM | #1 |
Rep 16
Ultra Racing Sway Bars (Front and Rear for F15, Unopened)
Still unopened. Added picture. Prefer Local Pickup Last edited by stopher; 01-13-2024 at 02:36 PM.. Reason: added picture |
06-08-2023, 02:01 AM | #3 |
Rep 16
boost4boobs66.50 |
06-21-2023, 08:47 PM | #8 |
Rep 480
06-23-2023, 01:25 AM | #9 |
Rep 16
06-24-2023, 12:36 PM | #11 |
Rep 661
I run both the front and the rear sway bars, absolutely zero swaying after the install. I've spent just north of a thousand for both bars together. Installation for the front is a pain, but if you have mastery of removing the entire front end, this can then be a cherry job. Anyways, just wanted to point out that these bars will greatly transform the way your suspension responds to turns and how it enables you to take the hard corners like a go-kart. Free bump.
06-29-2023, 02:05 AM | #12 | |
Rep 219
08-28-2023, 09:09 PM | #15 | |
Rep 546
Drives: 2018 YMB M3 Comp
08-28-2023, 09:10 PM | #16 |
Rep 546
08-29-2023, 10:04 AM | #17 |
Rep 661
When I swap the wheels to staggered wide stance setup, that helped a bit. When I replaced the springs to Eibach, and then Bilstein B6 shock absorbers, that helped a bit, It wasn't until I got both sway bars installed that I feel the true drastic difference for cornering improvement. I'll attest again, our OEM base sway bars are way too soft; these upgraded bars will get you a solid cornering ride.
01-02-2024, 02:39 AM | #18 |
Rep 16
01-08-2024, 11:09 AM | #19 |
Rep 807
Drives: BMW X5 XDrive35i
willing to separate?
01-13-2024, 02:32 PM | #21 |
Rep 16
X5 sway bars
01-19-2024, 02:46 PM | #22 |
Rep 130
What’s the part number of both front n rear. I have a E70 lots of suspension work and sway bars would be the last thing for me to do.
