11-20-2016, 08:05 AM | #1 |
Rep 529
Rear Brake Pads
I just got rear brake pad service notification after 25K miles but visually the pads look OK. Is it possible to reset the annoying warning sign myself without coding?
Thoughts on approx pricing for replacement at dealer? Many thanks! |
11-20-2016, 10:00 AM | #2 |
Rep 2,704
Service can reset after measurement (they enter measurement value). As notification is based on miles only.
11-20-2016, 03:04 PM | #3 |
Rep 210
I had same thing happen in my 328i and it ended up being a wire that had come loose from the sensor... replacement of sensor fixed it. They think a piece of road debris hit it while driving and severed the wire. There is a reason you got that message... The car isn't confused. Get it checked out.
2012 328i Sport Line - JB on Coral Red 2016 X5 35d M Sport Line - CBM on Ivory White and Black Dakota |
11-20-2016, 08:02 PM | #5 |
77
Rep 310
The service indicator can be reset as said above. You can have your dealer do this, or you can do it through the instrument cluster.
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
11-22-2016, 07:50 PM | #7 |
1150
Rep 2,426
The brakes on my E70 lasted about 47,000 miles before needing to be replaced, but I like to coast. So far I'm at 28,000 miles and the brakes all seem fine. I've actually been braking harder on this car, but they're still going quite well. I just hope they need replacing before the warranty goes out.
