      12-07-2016, 03:21 PM   #1
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
After 20,000 miles the two outside exhausts tips have blackened. Normal car cleaning stuff is not working on the chrome surface.
Any non-scratching cleaning suggestions?
      12-07-2016, 03:25 PM   #2
Alberta
Alberta's Avatar
2035
Drives: F90
You should try to polish them with a piece of steel wool.
      12-07-2016, 04:17 PM   #3
Steel wool and metal polish...
      12-07-2016, 04:34 PM   #4
TTBear
TTBear's Avatar
417
Drives: '20 Huracán/'19 M2Comp/'23 X4M
To clarify, use VERY FINE steel wool - 0000 grade. And only with a good metal polish, for lubrication.
That said, your exhaust tips don't look that bad. Always start off with the least aggressive technique.
Try this first (P21S metal polishing soap):
http://www.detailedimage.com/P21S-M1...P84/105-oz-S1/
With this (Powerball polishing ball on a drill):
http://www.autogeek.net/marine-powerball-mini.html
More often than not, this is all you'll need to get both the outside AND inside of the tips looking like a mirror.
If that doesn't work, THEN try 0000 steel wool, with a good metal polish.
Most importantly, after all of your hard work to get them looking fantastic, use a good metal sealant. Wolfgang's is excellent - http://www.autogeek.net/wolfgang-metal-sealant.html
More recently, I have been using a ceramic coating to seal the exhaust tips on our cars. It works AMAZINGLY well. After polishing, I'll apply the ceramic coating (I use Pinnacle Diamond wheel coating - it will handle the heat of an exhaust easily), and for a LOOOONG time, all it takes is a rinse with a water hose - at most, I rub my fingers around the edges with a quality car wash and sponge), and the tips are perfect again.
Hope this helps!
"Anima sana in corpore sano"
P111572.00
      12-07-2016, 08:12 PM   #5
GladiatorOwner
Drives: 22 M4C
Ahhhh, Mister Clean Magic Eraser!!!!!
And I'm not joking either.
F95inOC44.00
      12-07-2016, 08:31 PM   #6
kanvas
kanvas's Avatar
Drives: V8
0000 steel wool. Just cleaned my F15 tips the other day.
      12-08-2016, 09:14 AM   #7
PatrickC23
PatrickC23's Avatar
Drives: '16 991.1 911 GTS, '16 F85 X5M
2013 BMW ///M5  [0.00]
I use Klasse with just a micro fiber - seems to work well for me.
http://www.detailedimage.com/Klasse-...P54/500-ml-S1/
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red
      12-08-2016, 09:19 AM   #8
critical_mass
93
Drives: Ps
Hope this helps!
Is P21S safe to use on black, chrome exhuast tips also?
      12-08-2016, 09:35 AM   #9
TTBear
TTBear's Avatar
417
That's question I've been asking for ages, without a definitive answer.
My gut feeling on this is that in order to obtain the black chrome finish, the exhaust tip has to be clear coated (with the clear coat having a candy-coat tint in it). As such, I'd treat the finish just as I would with any clear coat - i.e. - I would NOT use P21S on it, just as I would not use it on my paint.
For this, I'd start safe, and use a good polish - Menzerna Super Intensive Polish would be a great start. If you need to get more aggressive, then go to a more aggressive polish, like Menzerna Fast Gloss (FG400), and follow either of them up with a finer polish (like Menzerna Final Finish (FF3000)).
If the tip is very blackened with exhaust soot, you could use 3000 grit sandpaper (it's safe for clear coat finishes, say, for scratches that are too deep for polishing), and then follow up the resulting haze with Menzerna Super Intensive Polish and then Final Finish.
And of course, apply a sealant/coating once clean - you'll be VERY thankful you did, because cleaning subsequently will be a breeze!
That's what I would do, anyway. YMMV
      12-08-2016, 09:36 AM   #10
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
Just a quick "thank you" to the many helpful answers, will post a grateful "cleaned tips" picture when done.
By the way, I thought that "carbon blackened" exhausts were gone with the last '70s carburetor Ferraris.
Our X5 M engines must be running heavily rich to produce so much carbon particulates - I must be missing something, as I believed that direct injection gasoline engines were intrinsically leaner.
Or it may be caused by our driving, rarely using more than 10 to 20 % of max engine power :-(
      12-08-2016, 10:49 AM   #11
dkhm3
dkhm3's Avatar
Drives: 991.2 GT3 2020 X3MC
i clean the tips every week, so i never have this issue.
Currently:
2018 GT3 2020 X3MC
Previously:
1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S
      12-08-2016, 08:40 PM   #12
Chadmatic
Registered Member
Chadmatic's Avatar
Drives: F15 35i M-Sport
This is the right way to do it!
      12-08-2016, 10:09 PM   #13
critical_mass
93
Drives: Ps
cheers! I'll avoid it in that case
      12-09-2016, 01:44 AM   #14
AlexLou1222
AlexLou1222's Avatar
Drives: 2015 X6M 2014 X1
I just use a moistured towel to wipe it after every car wash, and the tips still look new.
992 Turbo S
X7 M60
      12-09-2016, 05:22 PM   #15
F95inOC
F95inOC's Avatar
Drives: 2021 BMW X5M Comp
Yep! That does work!
I've also used that wadded cotton with polish in it that is meant for silver. Shines it right up...though I do it weekly when I was it so it keeps it relatively easy to maintain
