12-09-2016, 08:52 AM | #1 |
Rep 126
Auto high beam
Hi all
Does your auto highbeam work correctly Is it just a matter of dark conditions (highway driving at night), then flicking on high beam and pressing the 'auto' button near the BC button ?? Should a symbol for the "auto" high beam come on... As opposed to just the blue symbol !? |
12-09-2016, 09:59 AM | #3 | |
Rep 2,039
Drives: 2022 X6///M Comp
12-09-2016, 10:18 AM | #4 |
Driver
301
Rep 382
Note: Auto High Beams only works when the main Headlight Switch is in "A" position.
(It took me a while to figure that silliness out. Oops.)
cages:'18 M2, '15 i8, '15 X6M and '18 K1600GT
History: '96 Z3, '95 540i, '95 540iA, '00 M5, '04 X5, '88 M6, '89 750iL, '08 Z4MCoupe, '12 ActiveE, '62 R60/2, '76 R90S, '08 R1200GSA, '10 G450X I own no garage queens. If it's in my driveway, it's been ridden hard and put away wet. ...and now, with a light crust of Maine road salt. |
12-09-2016, 11:17 AM | #5 |
Rep 1,457
Mine works fine, but I find that sometimes it interferes with night vision. I think it is so strong that it blinds the night vision cameras ability to see persons or animals ahead of you. Night vision works fine when the automatic high beams are not on. Anybody else?
12-10-2016, 07:08 AM | #7 | |
Rep 126
12-12-2016, 03:49 AM | #8 | ||
Rep 8,364
12-15-2016, 09:56 PM | #9 | |
Rep 108
I have Night Vision and HBA (coded to GFHB) and they don't seem to affect each other. Night Vision camera picks up IR so it should be unaffected by visible light. Are the headlights coded? |
12-16-2016, 08:18 AM | #10 |
Rep 1,457
MochiEater, I'm not positive that the HB are causing my NV problem. What happens with my NV is that sometimes when there is an deer or a person just off to my left or right the HUD will give me a yellow or red picture depending on how close the object is, or it won't do anything. Sometimes the car beeps when an object is very close, other times it doesn't.
12-18-2016, 10:40 AM | #11 | |
Rep 66
Yes, Weird to be affected, have the complete night configuration with pedestrian detection with dynamic spotlight (not available in US) and with Adaptive lights works together perfectly, the system can spot a human or a big animal at 100 mts or more even with high beams active, all depends on your speed, under fog condition is incredible. |
12-18-2016, 08:53 PM | #12 | |
Rep 108
I've noticed that NV will only give a yellow or red alert if the hot object has the outline of either a human or 4 legged animal AND they are in my direct path or may move into my direct path given my closing speed. It can take a little while for the NV to color the target if the angle makes the outline indistinct. I have had situations where I pass deer standing still only 6 ft off to the side of the road and there is no alert. I have also had yellow alerts on deer standing in the someone's yard when my car directly faces them, even though there is no road and I would have to jump the curb and drive through the bushes and over the lawn to reach them. I also get false alerts where there is nothing alive out there that I can see. Usually an electric box or street light or other warm object. In my experience, NV tends to not alert for humans/deer that are just off to the side of the road, unless they are moving on an intercepting course with the car. I'm not sure how it works in non-US countries where Spotlight is activated. The usefulness of NV is definitely limited in the US where we have to either glance over to the screen occasionally or just trust that the alerts will work. |
11-10-2019, 09:26 AM | #13 |
Wisdom Searcher
58
Rep 193
Where is my HBA?
Waking up to ask basic question - do you have to have LED lights to have HBA? We have HID and our turn stalk does not have two buttons as shown in the graphic above. If we don't have it, can it be coded in?
Wife will be bummed if we can't access. Our much less plush Ford Edge had this pretty standard feature.
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3 |
11-16-2019, 09:51 AM | #15 |
Rep 2,194
Yes
