12-09-2016, 10:49 AM | #1 |
@BMWADRENALINE
120
Rep 96
High speed wobble 130+MPH???
Ok so today I experienced a strange wobble when accelerating, started at about 130 MPH and got worse the faster I went, let out of it at 145 MPH because it felt very unstable. I've had it up to the limiter several times before and it has felt stable every time. It was a little windy so I thought maybe that was the issue. I had the wheel torque and balance checked, all good. I also had an alignment performed and it was all in specs. The suspension was checked and nothing abnormal was found. Has anyone else experienced this?.
THIS WAS ON A CLOSED RUNWAY - NOT ON PUBLIC ROADS BEFORE EVERYONE STARTS FREAKING OUT!! Last edited by BMWadrenaline; 12-09-2016 at 12:06 PM.. |
12-09-2016, 12:18 PM | #6 |
@BMWADRENALINE
120
Rep 96
12-09-2016, 03:00 PM | #7 |
Driver
301
Rep 382
How old are your tires?
When were they balanced? Are all of the wheel weights still attached? Tires all at the 100+ mph suggested pressures? Pressures all equal (left to right) ? When was the alignment last done?
cages:'18 M2, '15 i8, '15 X6M and '18 K1600GT
History: '96 Z3, '95 540i, '95 540iA, '00 M5, '04 X5, '88 M6, '89 750iL, '08 Z4MCoupe, '12 ActiveE, '62 R60/2, '76 R90S, '08 R1200GSA, '10 G450X I own no garage queens. If it's in my driveway, it's been ridden hard and put away wet. ...and now, with a light crust of Maine road salt. |
12-09-2016, 03:23 PM | #8 |
153
Rep 388
i hit 147 in my F86 on the nj turnpike at 3 in the morning going to the airport...
the road was empty and i just had my dinan stage 1 installed so i wanted to see what it can do .... the f85 / f86 are very heavy... i also felt it wobble a little at that speed ... |
12-09-2016, 04:28 PM | #9 |
@BMWADRENALINE
120
Rep 96
Balanced and aligned about 200 miles ago, yes all wheel weights are still attached, tires have about 4mm tread remaining in rear, 6mm front, all pressures are set to 35psi. I also just had the car on a lift and had the axles checked to see if any were bent/warped. I already ordered rear tires so I'll just have to wait and see if it happens again at the next meet. Thanks for you help.
12-09-2016, 04:31 PM | #10 | |
@BMWADRENALINE
120
Rep 96
12-10-2016, 08:38 AM | #11 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
Do you have spacers in your hubs? (Wheel spacers). Or is it completely stock.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
12-10-2016, 08:50 PM | #13 |
Rep 56
Ive been at the aforementioned speeds (135-145mph) and have not experienced this.
There is slightly more movement but this is expected at those speeds. I dont feel unstable nor does the x5m wobble. |
12-11-2016, 10:37 AM | #14 |
Rep 8,809
At those speeds the slightest thing could cause massive vibrations. I would take it to a good tire shop that offers Road Force balancing. Also check for a slightly bent wheel as well.
12-12-2016, 07:29 AM | #15 | |
Rep 493
Wheel runout is a geometric problem, different from wheel unbalance which is a weight distribution problem; unfortunately you sometimes may have both together, which then makes wheel balancing such a tough, imperfect act. Runout may be very bad for shock absorbers, wearing them down inexplicably fast. New, perfectly round tires may gradually deform and develop some runout after fast driving, moreso if it's very hot. Balancing may well compensate runout's caused forces up to a speed, but beyond it they reappear strongly and if the suspension starts resonating, a vibration may appear suddendly and will stop only by slowing down quite a bit. In my case I tried a couple of times to reach max speed (no limiter, option 7ME) on a smooth German autobahn with no traffic (rare!) and the car was stable - little or no wind, 20" Pirellis Zero at 2.6 bar (~38 psi). |
12-14-2016, 10:18 AM | #19 |
Driver
301
Rep 382
Go fast. Take risks.
...safely.
12-23-2016, 12:30 AM | #20 |
Rep 45
I was impressed how stable the car was at speed, I was frequently over 200-210kmh on the track recently.
Braking from that speed after a few laps was another story, and stability control intervention in the different modes.. |
