      04-13-2018, 06:16 PM   #23
Dirty Cash
USAF Retired
Dirty Cash's Avatar
Drives: F15.50i
Originally Posted by Rotzy View Post
Seems like the tilt/telescope feature has had issues on these vehicles. Mine is making a squeaking/grinding noise when you shut the vehicle off. This is the second time it has done it in the last year and a half.
Experienced the same exact thing recently with the grinding noise. Took it in for service and mentioned it. Long story short, an “EXPENSIVE” part needed to be replaced in the column (as it was simpler to replace than to repair) and now all is well. Luckily it only cost me the $50 deductible (extended warranty).
      04-14-2018, 05:09 PM   #24
Ramps
Drives: 2014 X5 3.5i xDrive
Can this be coded out so the steering wheel just stays in place when you shut the car off? I worry all the in-out day after day will cause it to fail and will get expensive if it breaks again now that it’s not under warranty.
      04-15-2018, 01:44 AM   #25
mkdan2004
Drives: BMW X5 F15
Yes you can (fortunately).
Check this thread, last few posts talk about disabling it.
http://f15.bimmerpost.com/forums/sho...1356322&page=2
      04-15-2018, 02:34 PM   #26
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
http://f15.bimmerpost.com/forums/sho...322&page=2
Invalid thread
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      04-16-2018, 12:51 AM   #27
mkdan2004
Drives: BMW X5 F15
What do you mean? The link is not working? I opened it without problems. Just in case it does not work for some users, this is what needs to be coded to disable the steering wheel easy access function :
For F15 set the following to "Aktiv":
BDC Body -- V_MAX_AKTIVER_EINSTIEG_AKTIV
BDC Body -- V_MAX_DEAKTIVIER_EINSTIEG_AKTIV
Then check that the following have: wert_01 = 00 00
BDC Body -- V_MAX_AKTIVIERUNG_EINSTIEG
