      01-10-2019, 11:25 AM   #1
perry8912
Drives: bmw x5
Got a problem on changing the air filter on my 50i
Hey guys, a quick question, I was trying to replace the air filter with M’s yesterday. I pushed very hard, but I can’t have the center screw holes match to each other. Is it because I didn’t tuck the filter all the way in?
I saw there is a o-ring groove on the filter, should that groove go inside of the inlet flap or just stay outside? Because when I let go of my hands to screw the hole, the filter just pop out and nothing is holding it.
Any help or advice please?
      01-10-2019, 12:20 PM   #2
Bodie217
Bodie217's Avatar
92
Drives: '10 135i, '14 WRX, '14 Sequoia
That is just how it is, I had the same issue. I ended up forcing it.
Get each air filter (oval side) as deep into the intake tract as possible, then essentially line up the filter mounting holes, thread the screw through the 2 filter mounting holes, then push them down until the screw can be threaded into the hole. Hard to explain, but essentially you need to muscle it a bit.
-2010 BMW 135i - Titanium Silver - Procede v3/ETS 5" IC/AR Catless DP>N54mid>Berk Race/BMS OCC/VRSF Turbo Inlets & CP/SP rotors/Pagid RS29/APEX ARC8/Ohlins DFV/M3 Full Suspension and Bushings/Wavetrac LSD // 395rwhp/469rwtq on 91oct
-2014 Toyota Sequoia Platinum - Overlander
perry8912101.00
      01-10-2019, 12:21 PM   #3
bmwMthusiast
Drives: E36 328 Dinan, F15 50i M Sport
Put the screw through both tabs first, angle the filter openings down into their slots simultaneously. Then push down on the screw; it should seat the filters with everything aligned and drive the screw in.
A little silicone grease around the O-ring also helps.
E36 328 DINAN, F15 50 MSPORT, '56 Thunderbird, 02 Honda 919
perry8912101.00
      01-10-2019, 12:53 PM   #4
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Yes you need to wet o-rings and filters will slide all the way in. Central screw needs some muscles but this is small price to pay if you want x5m filters.
perry8912101.00
      01-10-2019, 01:16 PM   #5
perry8912
Drives: bmw x5
Appreciate all the helps guys.
I did what bmwMthusiast suggested, put the screw in first, angle the filter into their slot and push down the screw, and it works!! Hope I didn’t strip the thread.....
But another problem, If I use a screwdriver to touch the o-ring inside, I can see it moving in their grooves. So I’m thinking maybe the o-ring doesn’t set in the right place? Is that normal?
And if I drive the screw out, the filters pop out right away, which didn’t happen on the original 50i’s filter, and it got me worried. How can I know if the filter sealed the intake completely?
      01-10-2019, 07:52 PM   #6
sj22
Drives: 14 F15 50I
I can tell you its not a 100% flush fit, but its a good 80-90% flush fit when you screw it in. Take it out and try redoing it, or try putting your old filters back and you will get an idea.
Also from what I remember, the up and down sides are specific.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors
Past: 2013 750i xdrive, 2008 535xi
DuSh2113.50
      01-10-2019, 08:29 PM   #7
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Agree ^ it's not going to be 100% flush fit - it's just how it is with x5m filters - they are just a bit different.
      01-10-2019, 09:18 PM   #8
perry8912
Drives: bmw x5
Really? I thought the intake port are the same with M and 50i's filter and it does look like pretty similar.
      01-10-2019, 11:07 PM   #9
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Sorry for not been clear. Intakes are same, but size of x5m filter is a bit different, not by much, but enough for central screw to give issues. Also, lid closing is going to require a bit of force too from my experience - probably because x5m filters don't really sit as flush as 50i filters. I had to really push the lid down while tightening screws.
On the positive side - many of us have done it and so far no issues with it.
      01-11-2019, 06:29 AM   #10
pits200
Drives: 09 335i X-Drive Black Sapphire
I haven't read the entire thread but were you sure to get two different filters when using the M since the filter is asymmetrical and can only go in one way.
13717850055
13717850056
The 50i only uses one filter type so left and right don't matter 13717638566
It's crazy that it's so difficult for you, mine slid right in as if they were stock, maybe had to use an additional 10% of force to get the retaining screw lined up but nothing you're experiencing.
perry8912101.00
CT335xi684.00
      01-11-2019, 02:17 PM   #11
perry8912
Drives: bmw x5
13717850055
13717850056
Yeah, it’s two different M filters with same part number you mentioned.
I don’t know why it felt so difficult, but in order to set the filter in the right position, I had to use some tricks like other guy mentioned above. Even after I drive the screw in, I still feel the filter does not seal the intake completely.
Maybe I’ll try again this weekend, but I already felt the thread of central hole may be stripped a little
      01-11-2019, 04:24 PM   #12
Deubert85
Drives: 2014 F15 50i
Does anyone know where these filters go? I was replacing my air filters and cabin, but came across these as I searched for part replacement. 2014 X5 50i. Thanks
      01-11-2019, 08:49 PM   #13
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Doesn't Look like any cabin filters on the 50i. These are the three we have.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
DuSh2113.50
      01-11-2019, 10:38 PM   #14
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Those are from E70 x5 - previous generation x5 that was produced up to 2013. When searching online many vendors have outdated software that might give you parts for previous gen. In that case chose 2015 to be sure you won't be given wrong part.
      01-12-2019, 08:48 AM   #15
Duke I
Drives: X5
Mav, dude! Vacuum your car!
Duke
2018 X5 50i
2015 911 C2S
2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run)
Maverik2594140.00
      01-12-2019, 09:32 AM   #16
Deubert85
Thanks Dush. I was searching the engine thinking there can't be another set of engine air filters. Have you noticed any change in the M performance air filter compared to the standard
      01-12-2019, 12:08 PM   #17
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Not for stock 50i, but for tuned I noticed a bit improvement in acceleration. Usually people say buttdyno is noticeable when there's a 10% change. I'm not sure if it's that much in this case, but even if it's 5% it's still a lot: 5% for tuned n63tu is about 25whp Filters have 14% more volume flow when tested on flow bench by our forum member. I'm not sure if Stage 1 tune takes advantage of it fully or we need Stage 2 for that, but for the money they cost compared to stock 50i filters ($100 more than 50i filters) - why not? Folks with same engine n63tu in F10 forum spend literally $1-2k for a good intake (they have much worse intake design due to more limited space under the hood compared to our x5 cars).
emo6.50
      01-12-2019, 02:55 PM   #18
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Man that's an old pic. Probably washed and vacuumed the next day....probably not.
'06 C55 AMG (sold)
DuSh2113.50
Duke I106.50
      02-20-2019, 01:53 PM   #19
on3eighteen
Drives: 2016 BMW X5 50i
Do you think it'd help if I make the screw holes which connect the 2 filters a bit bigger? Sounds like that just may give the extra ~2mm needed while at the same time keeping the seal air tight. I'm just looking to take a little pressure off the screw b/c I can only screw it in halfway & the pressure is just too much that I can't tighten it any more or I'll strip the torx screw. I am headed to Home Depot to buy some silicone grease...I wonder if I can put that on the screw too...there's a ton of friction going on.
2008 BMW 335xi Dinan Stage 2 (sold)
2010 BMW 535xi JB4 (sold)
2012 Audi A6 3.0T APR Stage 2+ (sold)
2016 BMW X5 50i BPC or ESS
      02-20-2019, 05:15 PM   #20
on3eighteen
OK, so I got the filters in. I did 2 things, but I wish I had done 1 at a time. I followed the advice of using silicone grease, got it at Home Depot for $5. I think I only needed to do just that because it was so much easier to move the filters o-rings around once I put a very thin coating all around. But I also used a drill to make more room on the plastic holes where the screw connects the 2 filters. And at first I drilled the wrong end of the hole (the one farthest from the fitler) but I needed to make the end closest to the filter bigger, that's where there was tension. So I got it screwed in, and it was still harder to screw it in that I hoped, but it's done. Again, I should have just done the silicone 1st to see before messing w/ the plastic. Here's a pic...feedback welcome. And I included a pic of the ones I replaced. I can't believe for a CPO car w/ 33K miles & $47K, they didn't replace them, they are gross & I am calling my sales guy tomorrow just to say "Bad, bad, bad"...I don't expect them to do anything.
Maverik2594140.00
      02-20-2019, 10:23 PM   #21
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Damn that's pretty awful!
Glad you got them installed. It was t easy for me neither. Luckily I didn't have to do any extra stuff just s but if elbow grease.
'06 C55 AMG (sold)
