02-13-2019, 06:40 AM | #1 |
Rep 560
Wing Mirror Cover Removal
Hi Folks, I need some help! My X5 received its first battle damage to a wing mirror. The only damage apart from a scuff is a broken LED strip indicator.
My question is, can the mirror cover be removed without removing the mirror glass? I have searched the forums and there is a suggestion that a plastic shim can be used to pop the cover off. I have ordered a new indicator (£35), which was cheaper than expected, but I want to avoid the minimum 1 hour labour charge for BMW to fit it. (£120) Any help would be gratefully appreciated! |
02-13-2019, 07:13 AM | #3 |
Rep 1,354
Drives: 2022 X5 m50i
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
maDjzo861.50 |
02-13-2019, 07:37 AM | #4 | |
Rep 560
Replacement LED turning up tomorrow and I will decide how brave I am feeling |
02-13-2019, 09:48 AM | #5 |
Rep 1,354
You can pry it open using the plastic tools they sell on eBay or Amazon, that's what I did with mine. But you need a lot of patience and a steady hand.
2022 BMW X5 m50i
02-13-2019, 12:17 PM | #6 |
Rep 560
Good to know! I just had a look at it and don't fancy the idea of prising the mirror off. I guess that some silicone release oil could be sprayed inside the housing near the fastening points to help. Also thinking it is best done when the temperatures are not so cold as this could cause the tabs on the housing to break?
02-13-2019, 05:47 PM | #7 | |
Rep 1,354
2022 BMW X5 m50i
02-13-2019, 06:07 PM | #8 |
88
Rep 366
I did this to ours when we purchased it.
Some previous owner hit something, or something hit the mirror, and broke the LED strip. It looked like poop. To replace that LED Strip, you have to completely disassemble the mirror. Click each link, in order. Those are the steps required. Install in reverse order. No-Coding needed. https://www.newtis.info/tisv2/a/en/f...front/EIOF1mK5 https://www.newtis.info/tisv2/a/en/f...front/1LIP3ldp https://www.newtis.info/tisv2/a/en/f...front/EIfANsoV https://www.newtis.info/tisv2/a/en/f...front/EIfK0pMq https://www.newtis.info/tisv2/a/en/f...ont/1VnXj9rVP3 https://www.newtis.info/tisv2/a/en/f...ont/1VnXc1YR7i
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
02-14-2019, 08:57 AM | #9 |
Rep 560
[QUOTE=weareweird69;24377553]I did this to ours when we purchased it.
Some previous owner hit something, or something hit the mirror, and broke the LED strip. It looked like poop. To replace that LED Strip, you have to completely disassemble the mirror. Thanks weareweird - this now makes me think I am better off getting the dealer to do it. Having said that, the only part of this that concerns me is the mirror glass removal. I will have to look at it this weekend and make a decision! Thanks again. |
02-15-2019, 02:20 AM | #11 |
Rep 560
02-15-2019, 04:39 PM | #13 |
88
Rep 366
No tools, just fingers. Apply pressure along as much glass as possible, don't just hook one finger under it.
02-18-2019, 04:18 AM | #14 |
Rep 560
Job done and new indicator installed.
Getting the mirror off was the easiest part, but removing the cover was a different story. It was nothing like the youtube videos or various photos I have seen. The mirror cover was clipped and screwed onto the LED strip. This was not mentioned in the videos and consequently, I did break a clip. It's all solid when back together though. I will post some more photos when I get a minute. Thanks again everyone for your help and advice! |
02-18-2019, 08:32 PM | #15 | |
Rep 7,160
