      02-15-2019, 11:25 AM   #1
wankelman24
wankelman24's Avatar
Drives: 2016 BMW X5 35i M Sport
Last FREE Maintenance & Warranty Appointment - Question?
I made my last Free Maintenance & Warranty appointment today for the end of the month. Other than the usual checks that BMW will perform, is there anything I should ask them to check for warranty purposes? I have asked them to replace the brake pads. I have 47k miles so I'm sure they'll need to be changed out.
Your thoughts and suggestions are greatly appreciated!
WWW
“We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art.”
Chris Bangle (former head of design, BMW)
      02-15-2019, 02:12 PM   #2
HJ
Drives: F16 X6 CLS63 S
Guess it all depends on your relationship with your SA and how much they will go out of there way to find issues. First time back in a bmw since way back during the E46 days so I didnt have a go to SA like I do for my benz, ended up going to two different dealers. I still have till december until my factory warranty expires but I wanted the peace of mind so I got a ppi done couple of months ago at dealer #1 even though I mentioned some noises here and there, all they found was a squeak on the steering wheel and replaced a part and then informed me everything else seemed ok. Noises were still there so this time my friend suggested to take it over to his dealer where he has a good relationship with his SA he put in a good word for me. Dealer #2 ended up replacing the following; wishbones , 2 corroded rotors along with 2 pads, weather liner on sunroof and side doors, car battery, climate control faulty valve (this was the big one so they say) and 1 coil along with plugs all under warranty.
Appreciate 4
DuSh2113.50
201198.50
      02-15-2019, 02:13 PM   #3
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
WWW
Mostly ask to check for ANY leaks: all 3 oil gaskets in engine, plus TC (transfer case) and both differentials (back and front). DHP - for any leaks if you have DHP and also check rear bags for any cracks (if they are about to go). If steering column is making noise when tilting up/down and zooming. Control arms for any noise (if you are under 4 year original warranty).
Appreciate 4
HJ478.00
201198.50
      02-15-2019, 04:44 PM   #4
201
199
Drives: Bmws
I would say have your climate control taken a look at as well. I posted a thread about my problem due to weird noises coming on whenever the heat was on. It only took me 3 dealers to find and fix the problem but anything climate control related if its a big problem seems to be expensive to fix. They covered it under warranty but the invoice came out to over 2,800$
HJ478.00
      02-15-2019, 04:48 PM   #5
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
Spark plugs?
HJ478.00
      02-15-2019, 06:29 PM   #6
alphaod
alphaod's Avatar
Go around the interior of your car look for broken pieces like clips or loose trim pieces.
2015 BMW X5 xDrive50i
BMW CCA 509766
HJ478.00
      02-16-2019, 03:11 PM   #7
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
Get an end of warranty inspection done with a trusted independent mechanic and take the list to your SA.
      02-19-2019, 01:02 PM   #8
wankelman24
These have been great suggestions! Thank you all for your help!! Gotta Love this forum!!!
WWW
