07-21-2020, 03:21 PM | #111 | ||
Rep 1,859
Drives: 23' X7 40i M Sport
Maverik2594146.00 |
11-05-2020, 10:01 AM | #112 |
Rep 247
Drives: 2015 F15 50i, 2016 E89 35is
I used this guide to plan out a spark plug change and it helped greatly.
I would like to say, I didn't need any universal joints. I did use a Spark Plug Socket that had a swivel head, I'm not sure if that is what let me do it without U-Joints, all I needed was two 6-inch and one 3-inch extension I had misfires on 3 cylinders, 1 of those was really bad. I moved that coil to a new cylinder and the issue followed. I have ordered new coils and plan on changing all coils and tossing the 3 that reported misfires and keeping the 5 "good" ones as backup's since my X5 and Z4 both use the same coils. This write up should be used as the gold standard on changing plugs and coils. I followed it and it took me 1 hour to change the plugs. I will also stress the be sure you hand start the plugs to ensure you are threading the plug straight & blow out the spark plug holes before you pull the plug, I was surprised to see debris in some holes, nothing major, just a little bit of fine debris. Great DIY post!!! |
pennsiveguy3552.00 CT335xi684.00 |
11-06-2020, 09:05 PM | #113 | |
Rep 7,164
Kessler35is48.00 |
11-07-2020, 08:29 AM | #114 |
Rep 28
38K on original plugs. Swapped with M plugs. Really easy to do plug swap. I’ve never worked on the the N63TU engine and took me roughly one hour from start to finish. Not flash tunes but run jb4 and would often automatically switch to safe mode due to misfire I’d assume.never got a code for it though but runs great now
pennsiveguy3552.00 |
11-08-2020, 03:49 PM | #116 | |
Rep 1,564
https://www.amazon.com/ARES-11000-14.../dp/B07RR84RXB |
11-08-2020, 07:31 PM | #117 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Followed the instruction from OP and did the change today. It's not hard at all. Thanks for putting the instruction together!!!
2019 Cayenne Turbo
11-11-2020, 09:18 PM | #118 | ||
Rep 1,066
https://www.amazon.com/dp/B01MXJ3X7P...p_mob_ap_share
2019 Cayenne Turbo
11-16-2020, 10:16 AM | #119 |
Rep 1,859
Are the ignition coils something that should be replaced at the same time as the spark plugs? I'm at 49k miles on original ignition setup.
11-16-2020, 10:33 AM | #120 |
Rep 86
I like to replace them at the same time. My car started having missfires and I bought the whole kit from FCP Euro. Some people like to use them a little bit longer but while you're doing you might as well change out everything
classic_erik2811.50 |
11-16-2020, 11:48 AM | #121 |
Rep 7,164
I didn't change mine at my first plug change but I'm at 60k now so may change them all on the next one. Which I would have thought would have needed to happen sooner given my first issue arose at 25k miles and that was right after I chipped it. So I expect it to start giving issues soon again.
11-16-2020, 02:59 PM | #122 | |
Rep 1,859
Gkacmaz41.00 |
11-17-2020, 02:57 PM | #123 | |
Rep 1,066
I change the coils for every other spark plug change. With stock tunes, coils should be able to last 100k miles. But with aftermarket tune, spark plugs are changed every 30k miles, so 60k miles for coils. I got the coils and plugs from FCP Euro so lifetime warranty.
2019 Cayenne Turbo
11-17-2020, 05:00 PM | #124 | ||
Rep 1,859
Follow up question on the coils - Any experience with Bremi vs OEM?
11-18-2020, 12:58 PM | #125 | |||
Rep 1,066
2019 Cayenne Turbo
11-20-2020, 11:42 AM | #127 |
Rep 1,066
Based on my research, 0.030"
2019 Cayenne Turbo
11-20-2020, 12:26 PM | #128 |
Rep 7,164
Shouldnt need to gap them if you buy oem.
11-21-2020, 09:03 AM | #129 |
Rep 893
Completed this yesterday and it was the culprit to my vibration/lurching while accelerating. Some of my coils were stubborn and I used these to help pull them out:
https://www.harborfreight.com/11-in-...ers-64087.html |
12-08-2020, 04:34 PM | #130 |
Rep 1,859
I just had my spark plugs and coils done by the dealer. I have zero time these days to take on DIYs but wish I could have done this one.
Fun story. I used NGK 97506 plugs and asked the dealer to gap down to 0.60 mm since I didn't have a tool. They didn't want to do it so I had to speak with the service manager to convince them. He tried explaining that BMW doesn't recommend going below 0.70, even on their 760s and M8s. He was talking to me like I was an idiot. I told him to settle down and just gap them.
Maverik2594146.00 |
12-08-2020, 04:50 PM | #131 | |
Rep 109
12-08-2020, 05:00 PM | #132 | ||
Rep 1,859
Another interesting part of this story is that the service manager said they always install out of the box and don't even check the gap. The fact that they don't even check them when there are so many factors that could shift the gap during packaging and transit is crazy to me.
