05-03-2014, 03:38 PM | #67 | |
Rep 3,990
1004ron28.00 |
05-03-2014, 03:52 PM | #68 |
Rep 1,377
CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK will open the doors after ignition off. In BDC.
05-03-2014, 05:43 PM | #69 |
Rep 67
Any one tried to code to turn on the Wifi Hotspot and Glare-free Highbeam? I was able to turn on the Wifi hotspot feature but cannot tick the Wifi option in the iDrive. (It's there, but just cannot be selected)
For the Glare-free Highbeam, I didn't go with VO coding, but I changed the following: KAFAS2 => 3050 => FLA_ON_OFF => aktiv HU_NBT => 3000 => HIGH_BEAM_ASSISTANT => aktiv KAFAS2 => 3050 =>GLAREFREE_HIGHBEAM_ENABLED=>Werte=01 Yet, the Highbeam still does NOT work as advertised (no tunnel view when approaching vehicle ahead, and still auto-switched off when approaching on-coming vehicle) Anyone was able to get these two features working? |
05-04-2014, 11:17 AM | #70 |
Rep 81
05-08-2014, 10:23 AM | #71 |
Rep 81
So, nobody with ideas on a way to code to remember last fog light status?
1. Seat ventilation: Still weak with changed settings. Not sure if I should revert them to original settings or try lower ones. Any experiences out there? 2. Steering wheel raise on exit: I think there is an option to code to disable this feature but I haven't figured out which one it is yet, but would appreciate help: I am always impatient when starting my car and am ready to pull out. The steering wheel takes too long to return to its last programmed position. I find myself trying to back out of parking spaces while the wheel is still moving back to its position. Is there a way to code the X5 so that it just leaves the steering wheel position alone and doesn't raise it when you power off the vehicle? My last car had a menu option to disable this feature, but didn't see it in the settings menus. Thanks. I'm always on the lookout for new options to code if anyone has found anything new, I would be interested to hear about it. |
05-08-2014, 10:55 AM | #72 | |
Rep 28
if i want the camera on at all speed, do i need to change the were for SV_Deactivate_Speed too ? |
05-08-2014, 12:44 PM | #73 | ||
Rep 203
05-08-2014, 12:46 PM | #74 | |
Rep 203
05-08-2014, 12:47 PM | #75 | ||
Rep 203
05-08-2014, 01:19 PM | #76 | |
Rep 3,990
What we want is for the fog light setting to always be on with the headlight without having to always press the fog light button. So far no one seems to have understood or answered this. |
1004ron28.00 |
05-08-2014, 01:21 PM | #77 | ||
Rep 203
Please let me know if you guys find it. |
05-08-2014, 03:02 PM | #78 | |
Rep 1,377
05-12-2014, 02:56 PM | #79 |
Rep 32
Finally found out how to disable the automatic retraction of the steering column when exiting:
BDC Body / V_MAX_AKTIVER_EINSTIEG_AKTIV BDC Body / V_MAX_DEAKTIVIER_EINSTIEG_AKTIV both need to be set to active in addition, check that both: BDC Body / V_MAX_AKTIVIERUNG_EINSTIEG BDC Body / V_MAX_DEAKTIVIER_EINSTIEG are set to wert_01 = 00 00 enjoy! |
05-16-2014, 12:56 AM | #80 | |
Rep 83
Drives: G05 45e, Porsche Macan GTS
Has anyone successfully enabled rear DRLs without the lighting package, and if so, do you have the coding for it?? |
05-16-2014, 02:05 AM | #81 | ||
Rep 18,764
I haven't code one without the auto high beam, but it should work.
05-16-2014, 10:04 AM | #82 |
Rep 83
05-17-2014, 03:22 PM | #83 | |
Rep 81
05-17-2014, 03:51 PM | #84 | |
Rep 127
07-22-2014, 02:36 AM | #85 |
83
Rep 346
Sorry for the lame questions (new to coding, spent an entire evening reading tons of FAQs, manuals/etc. and setting up everything to work as intended), but:
1) Provided I'm not coding anything engine-related (DME ECU), is it safe to start the engine and then proceed to coding (in order not to stress the battery)? Or should I just turn the ignition on - i.e. w/o actually starting the engine? 2) Approximately how long do simple things take to code in (provided you know your way around e-sys and generally know what you're doing), like M-splash screen, video in motion (i.e. HU_NBT stuff) and trunk close via keyfob/button and some HUD turn-signals coding (i.e. HKFM and KOMBI)? |
07-22-2014, 02:44 AM | #86 | |
Rep 3,990
2) I would say it takes about 2 minutes per code because you have to locate which folder everything is in, but r33's cheat sheet makes things much faster. The more practice you have, the faster you will get because you will pretty much know things by heart. Here's something I wrote up with bits of help provided by many people from the forums: Quick tips: 1) Make sure under E-Sys => Options => Settings => Program tab => Memory Requirement => RAM is set to 1024 or you will likely be unable to read BDC. Do NOT use anything larger than 1024, or E-Sys will be unable to Open, and you will have to reinstall it. 2) When you connect - you connect via your VIN using the ENET cable and your computer. The Target connection is F25 since the F15 uses similar coding to the X3. Don't select the _DIRECT target version. That's only for use with MOTOR coding/modules, which you won't ever need or use unless something is really messed up and you get an advanced coder to help you reset your motor etc. 3) RIGHT CLICK to activate each folder or read each folder or code each module - DO NOT by any means CODE Default Values or CODE a whole folder - when you right click to CODE, do it for the individual module you are editing only. ESYS Coding steps simplified: Esys has a left window, a right window, a bottom left window where folders/files show up; it has a buttons section on the bottom right window area. 1) Read FA folder- located at the top left window - must right click and activate first and then you will be able to read it. 2) Read ECU - button on the bottom right side after you've selected the FA module 3) Read code for SVT folder in the bottom left window. 4) Code the desired module by right clicking it and selecting Edit FDL. 5) Save the editing using either the right button to save or right click to save or save via the prompt after it shows up. 6) Right click the module you just finished editing and select Code FDL.
07-22-2014, 03:33 AM | #87 | |
83
Rep 346
Only one question left on the table... How to code the Auto Start-Stop function to start as last used (i.e. disabled in my case ))? Found these in pre-LCI F10 (standard in LCI) cheat sheet: For last used: CAS => 3000 => TC_MSA_MEMORY => aktiv For always off: CAS => 3000 => TC_MSA_DEFAULT_OFF => aktiv Is it the same in the F15? |
07-22-2014, 03:39 AM | #88 | |
Rep 3,990
Funny you mention Auto Start-Stop. I actually found the same codes you wrote. From what I remember, CAS is BDC_body on the F15. However, I will double check when I load everything up. I'll post back everything up when I code it. I was going to do Default Off as I had chosen before when golovan remotely coded for me. Also, here's the F25 cheat sheet that I also found useful since we are using F25 as our target vehicle: https://docs.google.com/spreadsheet/...FTE9MS3c#gid=0 @r33, is CAS in BDC_body? Thanks.
Tags |
2014, coding f15, f15, f15 coding |
