04-08-2021, 10:00 AM | #617 |
Rep 535
for bmw speed Limit Information SLI Emulator for BMW NBT Retrofit NBT F3/F5/F7/X5/x6
https://a.aliexpress.com/_msT8lC7 I buy this one km\h and it‘s working on f20 for a one year |
04-13-2021, 04:31 AM | #618 | ||
Rep 21
Drives: F20 116i
04-15-2021, 01:28 PM | #619 |
Rep 457
Got a bimmer8 SLI module installed. Does anyone have a list of confirmed parameters that need configuring on an ID6 + 6WB + HUD vehicle? The list of parameters that are on the ebay listing is a bit hit and miss... Some of the parameters are not available, others mentioned in the G-series section are present on my kombi etc...
04-15-2021, 11:35 PM | #620 | |
83
Rep 379
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
04-16-2021, 02:29 AM | #621 |
Rep 457
I didn't try them, I was a bit apprehensive as I couldn't find everything, but I'll give it a go.
04-16-2021, 03:02 AM | #622 |
Rep 535
There is all what you need
【F Series】 ANZEIGE_NPI = aktiv KI_PIA_SPEED_LIMIT = aktiv SPEED_LIMIT = aktiv SPEED_LIMIT_GENERATION = sli_gen_2_npi RCOG_TRSG_APPL = aktiv RCOG_TRSG_TIMEOUT = aktiv 【G Series】 ADDITIONAL_SIGN_ENABLE = aktiv ANZEIGE_NPI = aktiv CB_TACHOZEIGERBAND = aktiv CB_SLI_NPI = aktiv PIA_SLI_NPI = aktiv RCOG_TRSG_APPL = aktiv RCOG_TRSG_TIMEOUT = aktiv SLI_PERMANENT_ENABLE = aktiv SPEED_LIMIT_ENABLE = sli TACHOZEIGERBAND_ENABLE = aktiv NO_PASSING_ENABLE = aktiv SPEED_LIMIT_UNIT_ENABLE = Wert_02 ( *If you dont want to display the speed unit kmh or mph, please set Wert_0 ) * If your vehicle have HUD (Head-Up Display) , ignore this if not applicable HUD_NPI_ENABLE = aktiv HUD_PIA_SPEED_LIM = aktiv HUD_SPEED_LIMIT_ENABLE = aktiv HUD_SLI_ENABLE = aktiv PIA_HUD_SLI = aktiv PIA_HUD_SLI_NPI = aktiv PIA_HUD_SLI_PORTIERUNG = aktiv PIA_HUD_VSLI = aktiv HUD_PIA_SLI = aktiv HUD_PIA_NPI = aktiv Coding to be modified for HU_NBT or HU_NBT2 SPEEDLIMIT_INFO = aktiv SLI_NAVI_DISPLAY = nicht_aktiv
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
Kolianovskyi87.00 Burniksapwet50.00 |
04-16-2021, 03:11 AM | #623 |
Rep 457
I have that, but for example I couldn't find the config parameters "ANZEIGE_NPI" or "SPEED_LIMIT" in the DKOMBI.
04-16-2021, 03:19 AM | #624 |
Rep 535
I find this two in kombi and I added them was diferent writing
HUD_PIA_SLI = aktiv HUD_PIA_NPI = aktiv It is not all there because it is mix between 6wa and 6wb but ANZEIGE_NPI and SPEED_LIMIT should be there
drdino138.00 |
04-16-2021, 03:24 AM | #625 |
Rep 457
Thanks for the info, I will take another look.
04-16-2021, 04:12 AM | #627 |
Rep 535
I check right now and no ANZEIGE_NPI and SPEED_LIMIT in cafd_00001060.caf.008_000_020 but you have
SPEED_LIMIT_GENERATION = sli_gen_2_npi HUD_NPI_ENABLE = aktiv HUD_SLI_ENABLE = aktiv KI_PIA_SPEED_LIMIT = aktiv HUD_PIA_SPEED_LIM = aktiv RCOG_TRSG_APPL = aktiv RCOG_TRSG_TIMEOUT = aktiv KI_PIA_SPEED_LIMIT = aktiv
drdino138.00 |
04-16-2021, 04:29 AM | #628 |
Rep 457
Yeap, looking at my notes these are the ones I could find on the DKOMBI. Interestingly enough, KI_PIA_SPEED_LIMIT was already at aktiv.
04-18-2021, 07:54 AM | #630 |
83
Rep 379
04-26-2021, 06:01 PM | #632 |
Great Teacher
1124
Rep 1,314
Drives: 06 e91 325ix
Honestly, you can’t. So install the adapter and see what happens, or ask someone who has one locally if it works for them.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
04-27-2021, 01:46 AM | #633 | |
Rep 766
Bimmer8 has a table showing supported countries here: https://bimmer8.com/products/bmw-spe...module?lang=en |
Kolianovskyi87.00 |
04-28-2021, 11:30 AM | #634 |
Rep 211
Anyone installed one of these along side a ghost immobiliser? Fitted one today and speed limit works fine on dash, cant get it working on HUD and Ghost also seems messed up as can no longer deactivated it with this installed.
04-28-2021, 03:50 PM | #635 | |
Rep 266
05-08-2021, 03:37 PM | #636 |
Rep 1
05-09-2021, 10:25 AM | #637 | |
87
Rep 381
So, I tried several boxes and can say, some boxes have a problem if there is no data for a particular street they show 150)))). I have found a box that shows - - - then. This is pretty good. Be aware. |
05-12-2021, 08:53 PM | #638 |
Rep 49
Same-would love to know how to do this!
'17 BMW 340i
