      09-09-2016, 04:40 AM   #1
py0413
py0413's Avatar
Drives: Slow
F15 winter tire question
hello folks,
I have a set of rarely used Bridgestone winter/snow tires in size 255/35/R20 and I am considering to purchase a set of wheel to mount those on and use them for the winter season.
Mine is the M-sport pack so it came with summer tires. My question is, would that set of winter/snow tire I have work on x5?
I have had heard several yes, but also several no and now I am very confused.
Any suggestions are very much appreciated. Thank you again guys.
Must stop eating..............
      09-09-2016, 09:03 AM   #2
fooit
Drives: 2015 X5d w/Mpkg
I dialed your tires into a wheel&rim calc and I personally wouldn't use them on your new X5 - it will handle and look weird is all I can guess.
I'd sell them on Kijiji and get the best second set of rims you can find in one of OEM sizes and the best matching set of winter tires.
Our X5 has Pirelli Scorpions Ice & Snow Runflat tires for winter, rears 315/35/20 and fronts 275/40/20.
      09-09-2016, 09:58 AM   #3
stewy604
stewy604's Avatar
290
I agree with fooit, not even close to the right sizing for your X5. What load rating are those tires as well? I'm running the same as fooit, Pirelli Scorpion Ice & Snow RFTs...they've been a solid performer for my needs.
2007 Suzuki GSX-R 750
      09-09-2016, 12:28 PM   #4
quad_drive2
Drives: 2014 BMW X5 35i M-Sport
Yeah... 255/35/20 is too far off from OEM sizing.
      09-09-2016, 04:24 PM   #5
py0413
py0413's Avatar
Drives: Slow
Thanks guys. I guess my choice now is to sell those tires and buy another set. Tire shops recommends going with 18 for winter use. They can get me a set tire/wheel for around 1800 Canadian dollar
      09-09-2016, 04:57 PM   #6
ramsal
Drives: 2017 X5 & 2018 M3
hey there,
Check out 1010tires.com, it's where I got my winter rims and tires (18"). The non staggered look is obviously not as aggressive or appealing but it works well especially if you will be venturing out into the snow. It helps to have the rear tire fit into the track made by your front tire, which is why I went for the non-staggered winter setup.
good luck!
      09-09-2016, 04:58 PM   #7
Terp335
116
Drives: E90 2011 335i M Sport
18's are probably ideal for best traction and thicker side walls for potholes. Personally, I think they look bad and opted to go with the 491 Winter Wheel package which includes 315s in the rear and 275s in the front. The Pirelli Scorpion Ice and Snow tires and they were great in bad weather as well as on dry pavement.
      09-09-2016, 05:01 PM   #8
ramsal
The Pirelli Scorpion Ice and Snow tires is what I got as well (in 18") and can confirm that they are well suited for our winter weather and terrain in BC.
      09-09-2016, 06:09 PM   #9
py0413
py0413's Avatar
Drives: Slow
18 sounds like the better option for me. Thank you guys, really appreciate all your inputs. Now I just need to get rid of that set of 20s I have in the storage. They are taking up way too much space.
      09-10-2016, 06:15 PM   #10
quad_drive2
I read somewhere, you may need at least 19" wheels with M-sport. Make sure you test fit the wheels
      09-10-2016, 06:16 PM   #11
Kuervers
Drives: 19 M2C HS,6sp 16 X5 35i
Check kijiji I bought some 298m 19s with one season on them for 1600. He paid 5k for them. Had to spend 180 to get the rears machine to fit tho
      09-10-2016, 09:50 PM   #12
fooit
What size are the tires and what width and offset are the rims?
Staggered or square setup?
Again, personally I would stick to OEM wheels and tires sizes.
      09-11-2016, 02:09 AM   #13
Doanster
Doanster's Avatar
627
Not true if you use the proper offset wheels. I run a square setup with 18s and 255mm wide Blizzaks. Def a good idea to test fit any wheel if you can before you buy.
      09-11-2016, 09:50 PM   #14
fooit
What width and offset are your rims?
      09-12-2016, 01:45 AM   #15
Doanster
Doanster's Avatar
627
18x8.5 +37mm
http://f15.bimmerpost.com/forums/sho....php?t=1211389
