      06-29-2016, 05:15 AM   #1
Joey26
Drives: BMW F85 X5M
How to Disconnecting / disabling the ASD on x5m f85
Hey guys
I just got SS catless dp installed on my x5m and I was wondering if any one on this forum has disconnected the ASD system on a x5m f85
Thanks in advance
      06-29-2016, 06:12 AM   #2
trev230
trev230's Avatar
351
Drives: 2022 M5C
There are a couple of threads on this. You can easily disconnect the wiring harness from the asd module in the cargo area behind the drivers side plastic panel that is removable. One of the members here started a thread with photos so check it out and you will be disconnected in no time.
Any info on the downpipes?
      06-29-2016, 10:53 AM   #3
Hammmerhead
Drives: 2016 X5M
I'm wondering if you change your exhaust, does the sound the ASD makes change as well? Some have said it is some sort of mic along with an amp.
      06-30-2016, 04:21 AM   #4
Joey26
Drives: BMW F85 X5M
Yea the downpipes are super sprint catless installed with the stock exhaust system.
I also had to remap the ECU
In regards to the sound it's a big difference compared to stock pipes very loud pops
      06-30-2016, 06:32 AM   #5
Alextacy
Australia
5
Drives: F85 X5M
Interesting choice, dont suppose you have any sound clips/videos?
Did you get this done at Evolve?
      06-30-2016, 09:48 AM   #6
SNAGuy
Drives: 2015 X5M
There is also a fuse you can pull that will turn the ASD off and from all reports from that thread that is the only use for that fuse.
I've been lazy and have not done anything yet but need to and will probably pull the fuse as that is the easiest to do.
      06-30-2016, 11:28 AM   #7
onfireX5
Drives: F90M5,F85X5M
http://f15.bimmerpost.com/forums/sho...&highlight=Asd
      06-30-2016, 11:46 AM   #8
Eyewire
Drives: 2015 BMW X6M
How about disable ASD with B&O System? Same?
      06-30-2016, 07:12 PM   #9
Joey26
Drives: BMW F85 X5M
I have a couple of videos on my phone Unfortunately I do not know how to upload it on the site
Yea Evolve done the ECU and a shop in Sydney installed the down pipes.
      06-30-2016, 08:21 PM   #10
Joey26
Drives: BMW F85 X5M
Originally Posted by onfireX5 View Post
all done I just disconnected the ASD
Thanks for the link
