08-18-2017, 09:37 AM | #1 |
Rep 3
Winter Tire Question
Hey Folks
I upgraded from a 2012 X6 5.0 to a 2017 X6 5.0 (The regular tires are 20 inch staggered) The winter tires for my old 2012 ... Can I use them on my new 2017? They are 19 inch Winters with the staggered bolt pattern. Thanks J |
08-18-2017, 11:44 AM | #2 | |
Rep 1,181
Since you stated that the current winter setup you have is 19" on a wheel that has a staggered bolt pattern, I assume it's an aftermarket wheel vs OEM? Or did you mean staggered sizes front to back? You need to provide the specs on those wheels. Actual bolt pattern, hub bore size (are there any centering rings installed currently?), and offset. Attach a pic?
08-22-2017, 01:27 PM | #3 |
Rep 3
Ahhh.. OK
My old winter setup was 19inch winter tires.(50R19) Wheels and Tires were OEM via BMW. Staggered front to back. 40R20 & 35R20 Not sure on hub size?? No Center Rings. |
08-22-2017, 02:35 PM | #4 | |
Rep 982
Do you know the BMW style number of your 19" wheels? I would suggest you try to bolt them on and see if they fit. They probably will. |
