01-08-2019, 07:48 AM | #23 |
Rep 2,194
Beautiful!
Lovely interiors here! |
iconoclast7265.50 |
01-08-2019, 11:50 AM | #24 | |
Rep 901
daytonaviolet1253.00 |
01-08-2019, 02:56 PM | #25 | |
OEM CSL Whore
1253
Rep 1,476
01-08-2019, 05:17 PM | #27 |
Rep 209
Better view of oak
daytonaviolet1253.00 Ibiza3636.50 |
01-08-2019, 11:23 PM | #28 |
Rep 901
02-26-2019, 09:52 AM | #30 |
Self-Deprecating Narcissist
7266
Rep 6,561
It appears that Nutmeg and Sonoma are the least purchased interiors.
02-26-2019, 12:22 PM | #32 |
7266
Rep 6,561
Ambient temp sensor. It's a thermometer that aids in regulating the HVAC.
02-26-2019, 06:00 PM | #33 |
OEM CSL Whore
1253
Rep 1,476
iconoclast7265.50 |
02-26-2019, 07:15 PM | #34 |
7266
Rep 6,561
Hahaha... the only thing that would happen is you breaking it.
03-02-2019, 01:31 PM | #35 |
Rep 239
here is my cheap $40 suede steering cover
03-02-2019, 11:54 PM | #36 |
Rep 120
03-03-2019, 06:06 AM | #37 |
7266
Rep 6,561
details on these two different ways?
03-03-2019, 09:23 AM | #38 |
Rep 239
Start button is from IND, the M1 &M2 and steering wrap are from aliexpress.
Start button less than 15 min to install, need to pull the trim off. Is very easy task. Just needs to be brave! The M1&M2 I try to pull them out, it won’t work. So I remove the air bag, center trim and shift paddle to install them, since I doing the wrap I need to take them off anyway. Total time is about 2 hours including to wrap the steering. I don’t have to remove the steering! Just the buttons installation, I will say less than 15 min! Last edited by pk9394; 03-03-2019 at 10:13 AM.. |
iconoclast7265.50 EricU660.00 |
03-03-2019, 09:27 AM | #39 |
Rep 239
The quick way is to use something like a glue puddle attach to the button and pull it out quick. This way may break the taps. And not always work but I also see many did this without any problem! The long way which is the correct way is to remove the trim and disconnect the button unit. This takes about 15 min to do. Is actually very easy!
03-04-2019, 01:57 PM | #41 |
Rep 92
03-08-2019, 04:34 PM | #42 |
Rep 1,779
I've heard using a magic eraser does wonders on a leather wheel. It cleans it up and restores the mate finish.
Current F95 X5M; E60 M5 6spd; Mclaren 570s; Aston Martin Vantage; Ferrari FF
03-09-2019, 05:06 PM | #43 |
Rep 92
Hmm. I think it's kinda abrasive. I will try a small spot on a old steering wheel. Hopefully it's doesn't affect the dye.
03-09-2019, 06:19 PM | #44 |
Rep 209
^^ Bad idea.
Magic eraser is indeed an abrasive and all you will do with that is remove the polyurethane top coat from the leather, making the situation worse. |
