10-19-2017, 10:47 AM | #1 |
Rep 5
Towing a 5000 lb boat/trailer with an X35i?
I'm new to posting here, but have been lurking for a while. I have a 21.5 foot wakeboard boat that weighs 3500 lbs + trailer, so right around 5k lbs altogether. My wife wants an SUV, but I need to tow.
How well would this work? I'm coming from a 2014 RT Durango with a 5.7L V8, and have no experience with BMW SUVs? I've seen Q7s pull boats like mine no problem, but interested how the 35i would do? I'm not interested in the Diesel and the V8 is more than I'm willing to spend. Thanks! |
10-19-2017, 01:44 PM | #3 | |
Rep 138
Drives: 2015 X5 xdrive50i M-Sport
Towing Capacity X5 35i? http://f15.bimmerpost.com/forums/sho....php?t=1025679 |
10-19-2017, 03:14 PM | #4 | |
Rep 5
I guess I'm asking how well it would actually pull something. I know it's rated for a lot. It seems high to me given the fact that it's a 3.0L Turbo with 300 ft lbs. I'm wondering if it will legitimately pull 5k lbs up a hill? |
10-19-2017, 03:32 PM | #5 |
Rep 865
I've pulled >5,000 lbs with our X5 with an execuhitch several times. Engine, transmission and standard suspension all handled it very well. At this weight, I have only towed the load for about 10 miles and up to about 50 miles.
I think the biggest challenge is suspension. The 3.5i has plenty of HP and torque to handle the load. Might have some issue on very steep grades, but likely no more than other vehicles. I had a 2000 Durango that could barely pull itself up a grade without overheating. Previous two vehicles I used were GMC Acadias; the BMW does a much better job hands down. If I was routinely doing it, I would strongly consider the Dynamic Handling Package (DHP); about a $4500 option if I remember and difficult to find on previously owned. Those who have DHP say they would likely never buy one again without it.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
10-19-2017, 03:43 PM | #6 | ||
Rep 138
10-19-2017, 04:45 PM | #7 |
Rep 12
I have a Moomba Outback V (20') wake boat that is probably pushing 4000 lbs loaded with fuel and toys. Sounds like my boat is a little smaller than yours, but I have no problems at all towing it with my X5 35i. I don't have experience pulling up huge grades, however, I have routinely towed 100 miles each way. I can vouch for the sturdiness of the Invisihitch, as the hitch connection has been rock solid. Gas mileage will suffer, naturally. I typically get around 14 mpg while towing on the interstate, but that will probably happen with any tow vehicle. I wish the side view mirrors were a little bigger on the X5 so that I could get a better view behind me. If anyone has a good solution for that, I'd be interested.
10-21-2017, 12:12 PM | #8 | |
Rep 102
Drives: 2014 X5 50i M Sport/2016 340XI
10-28-2017, 06:50 AM | #9 |
Rep 169
Anything can pull. It's stopping that I'm always concerned about.
A while back, I bought my 2015 GMC Sierra Denali 6.2L to tow my boat. To be honest, I have a feeling the my 35d can tow it...we will see in the spring! |
10-28-2017, 07:11 PM | #10 |
112
Rep 365
I have started using my 2017 X5 35i (xdrive) to tow my track car to the track. The car and open trailer weigh about 4300 lbs together and the X5 has handled the weight very well so far. The motor seems to have sufficient power to tow but on hills it does work a bit harder than a diesel would. Fuel mileage has been much better than I expected when towing on the highway. I am using the Invisihitch and it has been great. It is sort of a pain to connect the seven pin plug because it plugs in under the bumper cover so you have to lay on your back on the ground to connect it. The eyes on the hitch for attaching the safety cables are also sort of awkward and too close to the receiver so I have to use heavy duty carabiners to connect the snap hooks on my cables. I have the standard suspension (not self-leveling) and rear sag is not bad with 500 lbs of tongue weight. Braking is not a problem with my trailer, which has electric brakes, and I use a Tekonsha wireless brake controller, though BMW does sell a wired version of a different Tekonsha brake controller that also works with the X5. I also bought the BMW trailer wiring harness and lighting module, and had the X5 programmed to activate the towing features.
10-31-2017, 07:12 AM | #11 | |
164
Rep 317
I also use a finger to first to locate the safety chain loop while holding the hook in same hand and my left hand on top of bumper and leaning 1/2 over hook it through the loop. The carabiners I'm sure make it easier for you, but since they sway on the loop that might make it harder than the stationary safety chain loops which are built onto the unit. I try and eliminate more things that can rattle. It is an amazingly solidly built hitch. The Uhaul hitch I had on my last SUV was awful. The trailer on that hitch made so much noise. I leave mine on all summer as I like the protection it affords my bumper. Just took it off for the winter and love how invisible it is. $1,050, installed myself and well worth the money, and they code it for free byOkee from "codemycar.com" who does it by remote laptop and as an added bonus invisihitch (Steve in Atlanta) gives you a list of dozens of X5 features that Okee codes in for free at the same time he does the hitch. Now my key fob folds in my mirror when I press the BMW logo. If i hold down the unlock button all the windows and the sunroof open. He did about 10 coding features for my X5. OR maybe you are just built like my relatives who I know to have "short arms" . . . I know this because whenever a dinner check comes, they can't seem to get their "short arms" down into their pockets to ever pay for a check :
2016 X5 35i color: Jet Black
2014 Audi Q5 Premier Plus color: Ibis White Last edited by expidia; 10-31-2017 at 07:44 AM.. |
SYT_Shadow11500.00 |
10-31-2017, 01:57 PM | #12 |
Rep 5,066
I'm not experienced in towing.. actually Have zero experiences.
But wouldn't the weight of the vehicle that is doing the towing would also need to be considered?
10-31-2017, 02:17 PM | #13 |
164
Rep 317
Its like another poster has said . . . its not the "towing" . . . its the stopping that makes towing big rigs with small SUV's so dangerous.
2014 Audi Q5 Premier Plus color: Ibis White |
11-16-2017, 09:55 PM | #14 | |
Retired Curmudgeon
2986
Rep 4,054
If you use the factory electronics/wiring/towing coding, it's super stable (well, my E53 was). Coding uses the DSC to stop trailer sway should you be unfortunate enough to have that happen to you, plus it stops the parking sensors from going off when you plug into the electrical connector. I've towed a trailer that weighed more than my tow vehicle (as does every big rig on the road, fwiw). As long as you're within the conservative rating BMW puts on the vehicle for load and tongue weight, you'll be fine. Adjust your speed/stopping distances/turning radii.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
02-15-2018, 05:56 AM | #15 |
Rep 5
Firstly you can check the weight capacity given by the company to decide whether you can tow it. If the weight capacity allows, you can tow a vehicle following the instruction given by the company. But it is better choosing an auto transport company to transport your vehicle which will be more safe and avoid the risk of accidents and damage as you are going with family. There are many auto transport companies like We Will Transport It who transport your vehicle safely in fair prices to the destination.
08-07-2018, 11:46 PM | #17 |
Rep 7,164
08-09-2018, 11:31 AM | #18 |
Rep 1,497
Looks like it's rated to pull that but I'd worry about the tranny. My buddy has a 21' Axis that he pulled behind his Tacoma but after a season of towing it the tranny went out. He's since upgraded to a Tundra. Of course the X5 35i has more HP and torque but again not sure how the tranny will hold up over time. Does the xdrive have more towing capacity then sdrive?
BTW, what kind of wakeboard boat did you get? |
06-07-2020, 09:46 AM | #19 |
Rep 1
1700 lbs
so am i coorect though the numbers that people are stating in the 6000lbs is only with a trailer that has brakes? If the trailer does not have brakes the towing capacity of my 35i is greatly reduced to about 1700lbs?
06-07-2020, 10:21 AM | #20 |
Rep 1,547
Disc brakes on all 4 wheels. Towed this with E70 35d for 10 years. Have not done much towing with the F15
menelaos1226.00 |
06-18-2020, 04:45 PM | #21 |
Rep 94
Has anyone tried to reinforce the hitch so that the tongue weight for the hitch is increased?
My biggest concern is not the towing capability of the X5, but rather the hitch tongue weight rating. I have only found one hitch with a tongue weight rating higher than 600 pounds. I am trying to find a happy medium in getting a travel tailer with bunks that don't exceed the tongue weight with a sway control device attached. |
