09-11-2014, 09:26 PM | #23 |
Rep 1,133
Well they seem to be working. So in the end I removed 5AP and 8S$ form the VO and coded KAFAS2 and BDC_BODY. However, my wife still says they're kinda bright. She said if the windows weren't so tinted it would probably blind her.
09-11-2014, 09:36 PM | #24 | |
Rep 3,990
So for me to install this on another member's car...I need to do this light coding first before doing ANY BDC_Body fdl coding correct? Otherwise all the fdl coding will be deleted due to returning of everything to stock based on the VO Coding parameters. Thanks . I also edited the OP with your codes and turn signal bulb codes. I will continue to add more as members add to this thread. Thank you everyone.
09-12-2014, 01:00 AM | #25 | |
Rep 1,133
That's the easiest, VO code everything first and then FDL code. |
09-12-2014, 01:02 AM | #26 |
Rep 3,990
I thought so, thank you, Shawn .
09-12-2014, 01:37 PM | #28 | |
Rep 3,990
Which hardware do you mean? Can you be more specific? I'd be happy to point you in the right direction. I'm pretty sure I've outlined everything you need.
09-12-2014, 06:34 PM | #29 | |
Rep 156
mobile office? conect 2 phones via bluetooth ? or what? thanks |
09-12-2014, 06:36 PM | #30 |
Rep 3,990
@skalberti knows best regarding this option. Hopefully he can chime in.
09-12-2014, 08:13 PM | #31 | ||
Rep 18,722
09-12-2014, 09:44 PM | #32 |
Rep 156
09-12-2014, 09:56 PM | #33 | |
Rep 18,722
09-12-2014, 10:38 PM | #34 | ||
Rep 1,133
It's good to be bad
09-13-2014, 09:19 AM | #35 | |
Rep 156
09-13-2014, 09:25 AM | #36 | ||
Rep 1,133
It's good to be bad
09-13-2014, 10:23 AM | #37 |
Rep 18,722
I have coded 6NS few time on F15. Didn't pay attention so much on the hardware side, but noticed 2 phone capable, office capability became enabled, video from USB also enabled, etc after the coding. Only need to code the HU_NBT afterward.
09-13-2014, 10:29 AM | #38 |
Rep 156
Great and one of You guys can help me remotly i have all software cable lap team viewer, i just need token and the truck to arrive.
09-13-2014, 10:34 AM | #39 |
Rep 18,722
For sure, just let me know when you are ready.
09-13-2014, 12:25 PM | #40 |
Rep 55
09-13-2014, 02:18 PM | #41 |
Rep 3,990
This is correct. VO coding does not require a token, however, FDL coding does. He wants other features as well that require FDL coding, which is why we told him he needed to get a token.
09-13-2014, 02:42 PM | #42 |
Rep 156
well this are the codes that i like i maybe do not put all of them, do i need a token for this codes?
1.- break light flash on braking or Enable GTS brake force display 2.- Enabled fog lights with high beams 3.- Disabled legal disclaimers in Idrive and cameras 4.- DVD in motion 5.- M splash screen added in idrive 6.- open/close window with Key fob and comfort access 7.- open/close side mirrors with key fob and comfort access 8.- Rear hatch open and close with door switch and key fob 9.- Enabled OGG, XVID, and VCD video formats, Video via USB, Enable USB Video Playback (NBT iDrive) 10.-Lane departure in HUD 11.- Reduce time for folding mirror 12.- Disable auto start/stop by default: 13.- Factory Angel Eye Brightness Coding 14..- Xenon's firing on unlock or Low Beam Turns On When Unlocking 15.- Enable Rear View Camera While Driving At Any Speed 16.- Enable Enhanced Bluetooth Music Streaming 6NS 17.- Change phone ringtone (different ring or transfer phone’s ringtone to car 18.- Enable Sport Display (horsepower and torque gauges 19.- Turn signals in HUD 20.- HUD to show Entertainment list 21.- Sirius SAT Activation maybe only the sirius need a fsc i think. thanks |
09-13-2014, 03:03 PM | #43 | |
Rep 18,722
Sirius activation most likely need to have dealer to activate it.
09-13-2014, 03:19 PM | #44 |
Rep 156
thats the problem here in mexico no one have sirius the bmw do not offer it, and the configurator there is no sirius or satellite radio option, so what can i do, maybe retrofit? but i dont know if my x5 will have all the hardware and then only retrofit it remotly i guees.
