      08-25-2016, 05:54 PM   #2707
shahdad.lotfi
Drives: X5 35i
Originally Posted by shawnsheridan View Post
If you can read all ECU's without error, then updating your PSdZData will get you nothing. You only need new PSdZData if you can't read an ECU. If you can read ECU, then what you get is a function of the ECU firmware itself, not the PSdZData used to access it.
If 5AP and 8S4, which are the crippling codes for GFHB and VLD, are not present in your FA, then why do you say they are disabled in Italian car?
If you want to reset a module to original factory settings, simply activate original FA and VO Code the ECU. You do not need to restore any backup file.
Thanks Shawn for the clearance!! I didn't really know what PSdZData were for!
Regarding the GFHB, I am 100% sure that it is not working. Maybe being "not Active" is more appropriate word for my case. The reason I am sure is that, whenever I approach a car from back, or another car coming from other direction gets close to me, the headlights turn off automatically and turn back on when they are not near. This can also be verified from blue headlights indicator in my cluster being turned off/on. Also I have never seen my headlights make a tunnel, whenever there is a car in front. So I suppose it is not active.
Thanks again, and I am really happy if you can help me
      08-25-2016, 05:58 PM   #2708
shawnsheridan
shawnsheridan's Avatar
Originally Posted by shahdad.lotfi View Post
Thanks Shawn for clearance!! I didn't really know what PSdZData were for!
Regarding the GFHB, I am 100% sure that it is not working. Maybe being "not Active" is more appropriate word for my case. The reason I am sure is that, whenever I approach a car from back, or another car coming from other direction gets close to me, the headlight turns off automatically and turns back off when they are not near. this can also be verified from blue headlight indicator in my cluster being turned off/on. Also I have never seen my headlights make a tunnel, whenever there is a car in front. So I suppose it is not active.
I don't know that I can help. I have no idea if car is not designed for it or if it is actually being blocked somewhere. Since you do not have the Crippling Codes, the only other way it can be blocked is via Country Controller Code in FA if there is one specific to Italy.
      08-25-2016, 06:00 PM   #2709
shahdad.lotfi
Drives: X5 35i
Okay, so what should I really be looking for? do you want me to give you my VIN ? maybe that helps. it is WBAKR010100U00630
      08-25-2016, 06:02 PM   #2710
shawnsheridan
Do you have 814 in FA, which is NATIONAL VERSION ITALY?
      08-25-2016, 06:06 PM   #2711
shahdad.lotfi
Drives: X5 35i
No.
I have:
698=Area-Code 2
855=Language Verssion Italian
884=Italian/On-Board Documentation
VIN: WBAKR010100U00630
      08-25-2016, 06:14 PM   #2712
shawnsheridan
No.
I have:
698=Area-Code 2
None of that would do it, and I ran your VIN, and I see nothing else in your FA that could be restrictive. If it i snot working, it does not appear to be becuase it is being disabled. I would ask dealer if it should be working from factory or not.
      08-25-2016, 06:22 PM   #2713
shahdad.lotfi
Drives: X5 35i
Before I ever start coding, I asked the dealer and he simply responded that the GFHB is not available on X5, simple as that! So I suppose he didn't know any about coding!
BTW, I have another problem and I not sure if anyone here is experiencing it too! I have enabled video in motion and mkv files to be able to be read from USB. The problem I have is that after like 5-20 min of playing, the screen goes blank and only the sound is coming, and the only way to get out of this is to completely switch off the car, and wait for about 10 min outside and then get back into the car and replay it. I thought that is because of high resolution of the files, (1080p mkv) or playing from HDD, but after changing the format to a lower resolution and using a USB Key, it didn't seem to resolve the problem.
      08-26-2016, 12:15 AM   #2714
jloverock
Drives: F15 2016
Does anyone know what's meaning of those parameters below?
I have F15 2016, coding via esys 3.27.1, PSdZData v.59.2
MAPPING_STANDL_V_L(R)_OUTPUT
MAPPING_STANDL_V_L(R)_PART_OF
MAPPING_STANDL_V_L(R)_FUNCTION
MAPPING_STANDL_V_L(R)_PWM_1_STANDARD
MAPPING_STANDL_V_L(R)_PWM_2_REDUCED
MAPPING_STANDL_V_L(R)_PWM_3_REAR
MAPPING_STANDL_V_L(R)_FIXED_PRM
MAPPING_STANDL_V_L(R)_OFF_MODE
MAPPING_STANDL_V_L(R)_IGR_RELEVANT
MAPPING_STANDL_V_L(R)_DEPENDENCY_FUNC
MAPPING_STANDL_V_L(R)_DEPENDENCY_PWM
MAPPING_STANDL_V_L(R)_SPARE_OUTPUT
MAPPING_STANDL_V_L(R)_SPARE_PWM
MAPPING_STANDL_V_L(R)_DIMMED
MAPPING_STANDL_V_L(R)_DISABLE_OUTPUT
Thanks,
      09-01-2016, 08:50 AM   #2715
sp00ge
Drives: BMW X5 X40e
Coding software
Hi,
I was wondering if anyone could be as so kind to provide a link to download the required software and tokens please ?
Thanks in advance.
      09-01-2016, 09:09 AM   #2716
shawnsheridan
Originally Posted by sp00ge View Post
Hi,
Thanks in advance.
PM sent.
      09-02-2016, 10:23 PM   #2717
Don Juan
Don Juan's Avatar
Drives: 2020 X7 40i, 2020 I3s Bev
HELP!
For some reason now I can't connect to either of my cars!!
Little history. I coded my I3 a few months back perfectly and has not been into the dealership yet.
My X5 was just in for service and installed the MPPK and they updated the software so all my coding went away.
Now I try to connect with the same laptop that I had put away in the garage for awhile and the Connect by VIN is grayed out!!
I have shut down the car, unplugged the cable many times, restarted my computer, shutoff the wireless but nothing :-(
any ideas guys
here is a pic of my screen
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims
Retired
2020 X7 MSport 40i
2020 I3s Bev
      09-03-2016, 02:45 AM   #2718
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
any ideas guys
So you are getting fallback IP (169.254.x.x), but refresh does not pull up VIN with same IP as listed in connection details? Are you using any third party firewall or antivirus? Is the Engine running?
      09-03-2016, 05:37 AM   #2719
Don Juan
Don Juan's Avatar
The car is running. Then shutoff and locked for a while. Then computer rebooted and nothing
I'm getting a connection to the car but the esys cant read the vin :-(
Retired
2020 X7 MSport 40i
2020 I3s Bev
      09-03-2016, 02:31 PM   #2720
Neuera09
Did you upgrade your Esys version after the MPPK install? If you have not, go ahead and contact ShawnSheridan for the link. As for the connection issue, you might want to turn off your wireless connection and anti-virus software first. That did the trick for me a while back. Good luck!
      09-03-2016, 03:06 PM   #2721
Don Juan
Don Juan's Avatar
I have the latets Esys and pdza data files.No firewall nothing new :-(
      09-03-2016, 03:36 PM   #2722
Neuera09
Ya might need a new OBDII cable. Read up on this thread as well about the same issues.
http://f30.bimmerpost.com/forums/sho...696777&page=99
      09-03-2016, 04:13 PM   #2723
pcross71
Drives: 2016 X5 50
Hi guys - i coded everything i wanted about 6 months ago when my x5 50 (just long enough that i've forgotten the steps so have some reading to do...) was new but just got it back from first service and it got wiped. Could someone please provide the link for updated software and be so kind as to let me know what/how to update before i connect to car? Figure I might as well get updated before even trying. Thanks!
      09-03-2016, 05:13 PM   #2724
Almaretto
Almaretto's Avatar
2374
PM Sent
      09-03-2016, 05:44 PM   #2725
pcross71
Drives: 2016 X5 50
Thanks a ton.
      09-04-2016, 03:38 AM   #2726
Almaretto
Almaretto's Avatar
2374
Thanks a ton.
      09-05-2016, 12:14 PM   #2727
tcnac888
Drives: e46m3 s2k 958 kranch
does anyone in the philadelphia area can do the coding for a fee? please reach out to me
      09-05-2016, 03:42 PM   #2728
Bols
Belgium
231
Drives: F36 AW 6MT
Can the 40e plug-in be coded to always start in Max Edrive mode or does it have only the same ASS functions available?
