08-05-2016, 03:06 PM | #2641 | |
Rep 40,774
DirkH-0.50 |
08-05-2016, 03:24 PM | #2642 |
Rep 3,990
Sorry for the late replies to everyone. Just got time after a very hectic week. I'm PMing everyone back now, and I will update the OP with all updated information and links. Thank you to shawnsheridan for always helping everyone (GUYS, he is the one to PM for the latest links - I will update that). Almaretto, thank you for the suggestions/tips for updating the OP. I'll get on that tonight .
Side note: Could anyone who works in the technology field, please PM me. I would greatly appreciate your advice. Thank you .
08-06-2016, 11:26 AM | #2643 |
Rep 648
Drives: 2016 F15, 2015 F83
Does anyone have a link to the software installation instructions. The link on the OP (4. E-Sys Step by Step installation guide) does not work. I've tried the instructions on the thread referenced in #3 Step By Step Coding Guide, but I can't seem to make heads or tails of those instructions.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
08-06-2016, 01:15 PM | #2644 | |
Rep 40,774
FSociety3812.50 |
08-06-2016, 01:34 PM | #2645 |
Rep 648
2015 F83 M4 |
08-06-2016, 06:48 PM | #2646 |
Rep 3
So I managed to code a few things, but the one code that I really want, to get the car to unlock all doors when the engine is turned off (BDC module item 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK) is set to "nicht activ" , and does not have the "activ" option on the dropdown.
Googling that issue led me to a thread on another forum, http://www.bimmerfest.com/forums/sho...d.php?t=883746 where the gist of the eventual solution was to update EsysLauncher Premium to 2.5 so that the unchangeable VAM code becomes a changeable CLI code. What?? I thought the launcher was only a token generator to unlock use of the actual coding program (esys), not something that apparently reinterpreted the coding itself...? Can someone please spare this noob a link to E-Sys Launcher Premium 2.5.x? Thanks! Last edited by WildFireOne; 08-06-2016 at 06:57 PM.. |
08-06-2016, 07:18 PM | #2647 |
Rep 256
Drives: '17 F15 MSport
Could someone please pm me links to the latest software? Need to update before I can recode after service...
08-06-2016, 07:48 PM | #2648 | |
Rep 40,774
"* NOTE: 54.2 PSdZData and higher requires E-Sys Launcher Premium 2.x for FDL Coding. BMW AG made changes to PSdZData beginning with 54.2 PSdZData where they removed (trimmed) all descriptive text from CAFD (and FAFP) files, making FDL Coding of ECU's difficult, as the FDL Codes can no longer be easily located. E-Sys Launcher Premium 2.x uses historical CAFD data from older Untrimmed PSdZData releases to dynamically map the trimmed data back into E-Sys." PM sent.
FSociety3812.50 |
08-06-2016, 07:49 PM | #2649 |
Rep 40,774
PM sent.
08-07-2016, 09:25 PM | #2650 |
Rep 11
Guys,
have we got the coding for F15 to enable autohold when start? i googled, and seems F10/F12 has this coding. not too sure about F15? anyone any clue? Auto-Hold F10/F12 DSC 3000 Allgemein Funktion_AutomaticDriveawayRelease aktiv / Werte=01 nicht_aktiv / Werte=00 Works with: EMF->3000 Kodierdaten, 14->ADR_AKTIV->ADR_ein (ADR_Aus is the default) |
08-07-2016, 09:31 PM | #2651 | |
Rep 40,774
FSociety3812.50 |
08-08-2016, 03:07 PM | #2652 |
Rep 718
Tried coding a 2014 X5 using both methods for NGHB. Neither worked. More specifically, after coding the KAFAS module (Car has DA+), all of the assistance features malfunctioned. I had to put 8S4 and 5AP back and recode Kafas to get the assist features to work again. This has never caused issues before. Although I'm primarily used to coding my F80 without KAFAS module.
Has anyone experienced this? If so, what was the solution? |
08-08-2016, 07:40 PM | #2653 | |
Rep 8,364
08-08-2016, 10:45 PM | #2654 |
Rep 97
I have a bit of an annoying issue, everytime I put my F15 in reverse, the top view camera appears instead of the reverse camera.
Is there a way to make it default to reverse camera instead? |
08-09-2016, 09:09 AM | #2655 |
Rep 480
Lol, this is something a lot of people actually would want, but until now, nobody found the right coding for it. One quick check, is your car close to an object when switching to reverse? Because then it might switch to top view automatically.
08-09-2016, 09:11 AM | #2656 |
Rep 480
You were right, just some patience did the trick! I've heard that remark before in life. :-)
08-10-2016, 12:15 AM | #2657 |
Rep 97
Need to check, haven't paid attention to that but likely. Will report back.
08-10-2016, 12:57 PM | #2658 |
Rep 648
Hi guys.
I'm planning on coding my X5 for the first time this weekend. I'd like to start with VO coding VLD but I have a couple questions. 1.) By VO coding (instead of FDL coding), am I ensuring that a future dealer software update will not remove the VLD coding? 2.) After I remove the 8S4 code from my FA and VO code BDC_Body, do I then need to FDL code BDC_Body "LUT_FLC_FORWARDLIGHTING_Y" and "C_AFS_ENA" or are those only for those people who don't want to remove the FA code?
2015 F83 M4 |
08-10-2016, 03:17 PM | #2659 |
Rep 4
VIN Decoder
Is there is a site that I can plug in a VIN and get a list of all the options / packages that car has?
I have tried a few and while they do list out the options those options don't match with what the dealer says the car has. Yes, the dealer could be lying or be simply wrong but it's happened a number of times so I'm looking for confirmation. Confirm VIN decoder websites? I want to confirm it has Active Cruise Control with Stop&Go |
08-10-2016, 03:19 PM | #2660 | |
Rep 40,774
08-10-2016, 03:32 PM | #2661 |
Rep 4
Yes, that's one of the ones that didn't match.
5UXKR6C56E0J72998 is said to have Active Cruise Control with Stop&Go but I don't see the option listed on the VIN search. I believe the code is: S5DFA: ACTIVE CRUISE CONTROL+STOP&GO FUNCTION |
08-10-2016, 08:56 PM | #2662 |
Rep 2,404
I would trust the vin site over the dealer site.
EDIT---- Nevermind I was wrong, looking at the steering wheel on the car it for sure has adaptive cruise control. https://www.carstory.com/detail/2014...KR6C56E0J72998 |
