10-01-2016, 04:13 PM | #2795 |
Alpineweiss
11
Rep 213
Im having an issue that im not quite sure of on a 2016 X5. I can connect, read coding data, edit FDLs data, save, and code certain modules. Whenever I edit the BDC_BODY FDL, I get blank settings? in esys. Im not sure how to describe it because ive never seen it. I assume, I need the updated PSdZ files. I've attached a screen shot of below. Thanks for the help
2013 335xi 6MT M-Sport
10-01-2016, 04:19 PM | #2796 | |
Rep 176
10-01-2016, 06:54 PM | #2797 |
Plenipotentiary
2614
Rep 3,046
Anyone up to try remapping of the tail lights? It looks like splicing of harnesses for ECE tail lights may not actually be necessary. All the differences between US/ECE illumination are intentionality coded to do so. If the internal circuitry was different, the output map would not have all the circuits active with function redirection. Changing the redirected outputs should enable a US tail to illuminate the same way as an ECE (just with red indicators remaining).
10-01-2016, 09:17 PM | #2798 | |||
Rep 8,364
10-01-2016, 10:22 PM | #2799 | |
Plenipotentiary
2614
Rep 3,046
Almaretto2374.00 |
10-03-2016, 09:45 AM | #2800 | |
Field Marshall
32
Rep 117
With my car we (r33 and I) determined through trial and error that the paddle wire does not exist in the steering column for whatever reason and simply inserting 2TB in FA and VO coding BDC_Body, Kombi, and ICM (and paddles off) didn’t work for me. 2TB would work fine, but the car continuously looked for the paddles and since there were none it would generate an error code and my transmission would randomly switch in and out of manual mode. So opasha VO coded each and every folder except DME and coded paddles off, cleared DTCs (error codes) and I haven’t had a problem since. Hopefully things will go smoother for you. Last edited by BitteEinBit; 10-03-2016 at 02:53 PM.. |
spike5150421.50 |
10-03-2016, 11:03 AM | #2801 | |
Rep 211
Tried coding out for the 1st time yesterday as having to select sport mode every time I get in the truck was driving me insane. Had a few bumps getting it all going at first but some quick searches on here solved all my problems. Just wanted to let anyone else know the above code works to remember last driving mode on my 2014 X5 35d. Cheers djsaad1! Last edited by TallTrees; 10-04-2016 at 09:42 AM.. |
10-04-2016, 01:05 PM | #2802 | |
Rep 65
10-04-2016, 05:31 PM | #2803 |
Rep 8,364
10-09-2016, 10:51 PM | #2804 | |
Rep 1,746
Awesome! Thank you so much. I am due to for service soon, with possibly work that may get my software updated & codes wiped, so I am going to hold off this until after I get my X5 back from service, then I will go exploring.
10-11-2016, 07:10 AM | #2805 |
Rep 211
Coding experts challenge. Plenty of us out there who hate the light/sloppy steering feel, switching to sport mode helps but it's still not enough at low speeds. Hoping someone can find the code section to allow a change to the steering weight.
10-12-2016, 08:09 AM | #2806 |
Rep 648
Drives: 2016 F15, 2015 F83
10-14-2016, 03:28 PM | #2807 |
Rep 9
UK
Hi all , just joined
Have just got a 2016 40e and plan to make a few changes. I am a programmer by trade so don't expect any problems Cable is on its way so just need the software , anybody assist? Cheers guys |
10-14-2016, 03:36 PM | #2808 |
Rep 40,774
PM sent.
Howi0.00 |
10-14-2016, 09:03 PM | #2810 |
Rep 176
F15/F16 steering wheel heating temperature
Does anyone know if we can raise the temperature on the steering wheel, my F16 seems to be warmer than my F15 steering wheel. I have a M sport steering wheel on the F15.
10-15-2016, 06:57 AM | #2811 |
Rep 9
Agreed it doesn't seem very warm, also the seat heating on F15 is no where as warm as my old E70?
10-15-2016, 06:30 PM | #2812 |
Rep 591
Here is a challenge for the experienced coders here, I have a 2016 X5 40e, I coded pretty much everything based on this AWESOME thread (after changing my drawers a couple of times thinking that I tanked the car). I ran into two snags, the first one unlocking all doors when the engine is off, this code VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK is only set to inactive and there is not option to select active and this code is missing CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING. I am using PSdZDATA 59.4 Lite and ESYS Launcher Premium 2.4.3 with Token Generator. The second one is in enabling sport+, I did the VO coding, added 2TB, recoded CFADs and cleared errors and went to code, I then inactivated the paddle shifters since I do not have them but I was not able to find ICM / ICMKOD_B_SPORTLENKUNG it does not exist. Any help is appreciated, you guys are extremely helpful, I leased the care based on advice here and coded it also based on advice here......... thank you.
10-15-2016, 07:14 PM | #2813 | |
Rep 591
What happens if you code the DME? |
10-15-2016, 07:54 PM | #2814 | |
Rep 8,364
If engine is running, you can end up bricking or corrupting ECU. Anything from requiring an injection procedure to needing a flatbed tow are possible. Last edited by Almaretto; 10-15-2016 at 08:05 PM.. |
10-15-2016, 08:07 PM | #2815 | ||
Rep 591
As for the sport+ I posted before driving the car, and I'm not sure if this was always he case I've only been driving the car for two weeks, when I press sport twice sport+ shows up. |
10-15-2016, 08:18 PM | #2816 | |
Rep 8,364
Running the engine also has the advantage of climate control. If you are quick and utilize offline coding, then engine does not necessarily need to run. Engine should just not be running while coding DME/DDE. |
