11-25-2014, 04:46 PM | #507 | |
Rep 3,990
FEM_BODY/3062/MAPPING_TAGFAHRL_V_L_PWM_LEVEL_1/change from 32 to 64. Changes Day-Run Light Brightness (Left) FEM_BODY/3062/MAPPING_TAGFAHRL_V_R_PWM_LEVEL_1/change from 32 to 64. Changes Day-Run Light Brightness (Right) again, for us, we look in BDC_BODY. I haven't checked this on mine because mine are already 100% brightness. Don't go into 3062 because that is for different BMWs. BDC_Body numbering might be a little difference so simply copy and paste the full code name and search this way.
11-25-2014, 05:07 PM | #509 |
Rep 3,990
Nope, that's engine specific. I looked this up because I remember seeing your post or something similar before. There's no way to increase this from current coding. It may be somewhere hidden, but I know it's engine specific.
11-25-2014, 05:23 PM | #510 | |
32
Rep 338
Omar, thank you very much brother. Everything works perfectly fine except for folding mirrors. Not sure if I asked you for that option. A big thank you..
11-25-2014, 05:28 PM | #511 |
Rep 3,990
My pleasure, Siraj . Maybe one code wasn't activated. I can check for you via Team Viewer in 1 hour. I'm running errands at the moment. If you're comfortable coding, you can check the cheat sheet or the screen shot I posted of it two pages back near the bottom.
11-25-2014, 11:51 PM | #512 | ||
Rep 1,746
I am really interested in this coding my halos to be %100 too because with LEDs, halo's get lost in the brightness of the headlights, and while I don't mind the stock brightness of DRL halos, I really want to get %100 or at least brighter halo's with low beams.
11-25-2014, 11:56 PM | #513 | |
Rep 3,990
11-26-2014, 12:21 AM | #514 | |
Rep 1,746
11-26-2014, 12:24 AM | #515 | |
Rep 3,990
11-26-2014, 02:47 PM | #517 |
Rep 3,990
I posted a few pictures of it a few pages back, but I don't see your pic. I think it didn't post correctly.
11-26-2014, 04:41 PM | #518 |
Rep 6
Speaking of rear camera. Is there a way to code it to show full screen? I recalled on a X5 loaner I had a couple months back that it can display rear camera in full screen but that X5 has the surround view feature.
My build does not have the surround view so it shows the rear camera in 2/3 of the screen with the PDC occupies 1/3. |
11-26-2014, 04:47 PM | #519 | |
Rep 40,774
11-26-2014, 04:59 PM | #520 |
Rep 6
Actually I am asking about seeing the normal rear camera backup view in full screen, not the trailer view (which is pretty cool too after coding it)
11-26-2014, 06:29 PM | #521 |
Rep 3,990
As far as coding, no, there is not. The only way I think to even have this available would be to disable the Parking Sensor view (one of the two P's on the left option scroll). I don't even know if that would work, but you can try that.
11-26-2014, 07:34 PM | #522 |
Rep 1,746
Now that you mentioned the full screen (Panorama View) it also has a way to detect approaching vehicle, so it actually works better than rear view (reverse) camera, or it's supposed to work better. It has such a high viewing angle, too bad the standard rear view camera does not do that.
However I am not very happy with the front camera, you really can't tell how far you are from an object because it's mounted way too high. We really need individual corner cameras in next upgrade. @opasha, in my E70, I was able to drive up and down on my driveway with just the DRL's on, it illuminated the walls on the sides and the front just enough for me to see everything, and of course it looked damn cool, with LED's on F15, I can't do that anymore, so they are definitely a lot dimmer, although I can't compare them to Non-LEDs on F15 if they are also weaker than E70. So I think overall halos on F15 might actually be weaker, especially if they are at %100 in DRL mode. (not sure if coding makes any difference, like you said)
11-26-2014, 07:54 PM | #523 | |
Rep 3,990
11-26-2014, 11:05 PM | #524 | |
Rep 1,746
-Edit, @opasha Checked but I do not see above in cheat sheet or on pdf. Also, is there a reason why your codes in first post are not being added to cheat sheet? It would be nice to have them all in one place.
11-27-2014, 12:07 AM | #525 | |
Rep 3,990
EDIT: I'm currently updating/organizing the Cheat Sheet . Stay tuned.
11-27-2014, 03:50 AM | #526 |
Rep 3,990
I have finally updated the F15 CHEAT SHEET: https://docs.google.com/spreadsheets...9s4/edit#gid=0 in the OP with the OP coding list (they are all deleted now and I will only post FA coding in the coding list), lots of new codes, and I organized it all so each ECU is together for much easier coding (the codes that were together in different ECUs I left alone and just added around them to make it all flow). It took me a good two hours . I will add more as I test them when I get my car back. Right now I added the ones I think/know work on our F15. If one in there does not work, let me know and I will remove it. Also, if you guys find new codes that work, let me know and I will update the cheat sheet. I hope this makes everything much easier for everybody .
I have also added notes for some of the codes so you will see tiny black corner marks for codes that have my notes. If anyone is confused on anything, I will add notes to those codes as well. Thanks. Now to catch up on some much needed sleep, goodnight/good morning!
11-27-2014, 10:02 AM | #527 |
Rep 18,715
@opasha, thank you for the updates on the cheatsheet.
