09-23-2017, 06:37 PM | #397 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
You are right to wait until 11.1 is out there
09-23-2017, 11:58 PM | #398 |
Rep 3,742
I am having issues coding mirror open/close via the key. I purposely did not equip the vehicle with comfort access. I have had comfort access on previous BMWs as well as on Toyota vehicles and it is pointless to me. Nevertheless, I would like to be able to pull in the mirrors and extract them via the key.
Anyone without comfort access that has coded this please advise. Thank you Last edited by SCA; 09-24-2017 at 03:38 AM.. |
09-24-2017, 11:51 AM | #399 |
524
Rep 2,146
Solved my issue with Bimmercode, it was just a matter of cliking on "Restore purchases" and coding was unlock again
....Life is too short to drive boring cars
09-26-2017, 01:25 PM | #400 |
Rep 33
Apologies for late response as well as incorrect info, I misread your question and so please disregard my statement that I was able to code this feature.
I am still missing ability to code wing mirror folding, totally absent from my options, seems like there are some updates missing. I have since coded this by digging out my old windows machine and cable, so for me this app purchase and the adaptor has been a write off. |
09-26-2017, 01:26 PM | #401 | |
Rep 33
09-26-2017, 01:56 PM | #402 | |
Rep 3,742
The only exterior mirror option available for me is to code fold and unfold via comfort access. |
09-28-2017, 10:22 AM | #405 | |
Rep 33
Update: the App refresh has now added (for me) the Mirrors section - moot as I coded via Esys. but in case anyone else had some issue. Last edited by Pkitch; 09-28-2017 at 01:15 PM.. |
09-28-2017, 10:23 AM | #406 |
Rep 33
Yes this is what I was looking to restore (after dealer recall and ECU flash), I had previously coded with ESYS and was hoping to cut some corners. Anyway per your other post, I will see if the App update has corrected this, will be nice if I need to make any future changes.
09-28-2017, 01:14 PM | #408 |
Rep 33
09-28-2017, 01:19 PM | #409 |
Rep 661
Thanks!
Ordered 2018 M3 SO/SS extended, ZCP w/ black 666M, DCT, Exec
09-28-2017, 03:50 PM | #410 |
Rep 7,063
Worked for me this morning!
09-28-2017, 03:51 PM | #411 |
Rep 7,063
So got everything I wanted coded. Only issue I ran into is when closing the trunk with the remote it used to be press to open and press to close. Now when I coded it, I have to keep pressing to close. Opens fine with button press
Also received these malfunctions which made my heart drop. Turned off the X5, unplugged V-link, walked out, locked it and turned it back on and it was all gone like that. All coding still in tact. I do wish however there was a favorites menu check list to do it all at once so I do not have to keep going through all option menus.
09-29-2017, 08:26 AM | #412 |
Rep 7,160
Errors are common
09-30-2017, 02:47 PM | #414 |
Rep 666
I just completed my coding this morning. When I was finished, my engine light was on and I had lost my door chime.
I restored everything from backup -- restoring BDC made the engine light go off. I restored the others I touched too. I still don't have my door chime back though. Any ideas? When I coded with my laptop before they installed MPPK, I had deactivated the camera and seatbelt warnings, but I still had a door chime. That's what I want now too. However, what I have now is stupid BMW default + no door chime!! What? ======= Edit: I reprogrammed this afternoon and I did BDC last instead of first. I was not left with an engine light this time. However, still no door chime. Also, I set turn signals to 5 and the setting doesn't stick. The app still says 5, but the car is only doing 3. I went into expert mode to check on the actual setting and couldn't find it: BDC_BODY/3068/BLINKZYKLEN_ANZAHL_TIPP. ======= ok, just found out that the code may be PIA_DEFAULT_TIPPBLINKEN. I'll check that later. Last edited by Barbja; 09-30-2017 at 04:08 PM.. |
OFFWHITEX5325.50 |
09-30-2017, 09:22 PM | #415 |
Rep 152
Got It Working And Coded
Ok so I tried it again today and it updated. I coded my mirrors, angels with fog lights and tailgate closing with key fob. Thanks to all the wonderful people putting the DIY info up here. I coded it the simple way with the VGate Wi-Fi OBD2 and the Bimmercode App. So easy a caveman can do it, should've been the slogan. lol
2ND X5 IN 6 MONTHS. LET THE MODS BEGIN AGAIN.
09-30-2017, 09:25 PM | #416 | |
Rep 666
'unlock on engine stop' isn't taking effect either. I looked for VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK in expert mode and didn't find it. I haven't checked for CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING yet. |
09-30-2017, 10:22 PM | #417 | |
Rep 666
I also found CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING. Its set to active though. Hmmm |
10-02-2017, 09:04 AM | #418 |
Rep 113
Go to expert mode and change the werte value to 04 or enter a new value. It will work if you have the older iStep version. It did not work for me using BimmerApp, I have to use E-sys.
