05-29-2018, 11:49 AM | #1 |
Rep 1,497
F15 X5 35i Oil Change
Feel like a noob asking, but I've searched and can't seem to find much info on oil change intervals as well as preferred oil choice. Keep finding info on 35d and 50i. Please be so kind to point me in a direction. Thanks
05-29-2018, 11:50 AM | #2 |
Rep 1,915
I change it every 5 to 6K miles, personally.
Mobil 1 OW-40. |
Jenya B144.00 Maverik2594151.50 |
05-29-2018, 12:10 PM | #3 |
Rep 525
Buy oil filter , and oil , remove engine cover , open the lid , unscrew oilfilter housing and lift up the SUV , from the bottom open access "door" unscrew the bolt , drain the oil for 10 minutes . Use NEW copper washer from oilfilter set , put on bolt and screw it back , do not overtight . Close access door . Put truck down . Put oilfilter and screw the cap , dont forget new oil ring . Use funnel to fill up the oil into the engine , check oil level .
Ickdeep5730.00 |
05-29-2018, 12:35 PM | #5 | |
Rep 1,497
05-29-2018, 12:38 PM | #6 | |
Rep 525
05-29-2018, 07:20 PM | #7 |
483
Rep 317
Oil Spec for N55 (35i) are LL01,
Castrol edge 0w-40 European formula, you can find them in wal-mart for $22-$24/gallon and most automotive store for higher tho, you'll need 6.5 Quarts. can pick up an oil filter at dealer for around -+$20 |
05-30-2018, 10:54 AM | #8 | |
Rep 1,497
Walmart has everything! I'll check that out. Also, going to look for the OEM filter on ebay. |
05-30-2018, 12:41 PM | #9 | |
483
Rep 317
When i got my oil filter for my X5 35d, napa autoparts was charging around $49.99 for a oil filter (because it was "specialty" BS filter) while the dealer was only $15, but i had a random discount and it came out to be $10. So check around with the dealers around your area. However if dealer is expansive (more then $12-15 is overpriced for N55 filter) Your aftermarket options are Mahle (oem) Part# OX 387 D Mann (Very good aftermarket) Part# HU 816x Avoid (filter element will collapse and twist) FRAM WIX Beck & Arnley Last edited by Mr.47; 05-30-2018 at 12:52 PM.. |
sweeper631.50 |
05-30-2018, 02:00 PM | #10 |
Rep 110
well, just go to the dealer for an old change every 5k miles or 6 months for around $75 and enjoy coffee and checking out new cars, unless you enjoy playing with your dirty hands!
If you are out of warranty, just go to your local trusted mechanics for bigger jobs. |
05-30-2018, 04:41 PM | #11 |
Rep 1,180
Honestly curious, is there a reason folks are changing their oil at 5-6k vs the recommended intervals from BMW?
Has anyone done a blackstone lab analysis of their engine oil at 5-6k vs 10k? I'm curious if there is a notable degradation of the oil at the higher mileage interval.
2018 X5 35i M-Sport
05-30-2018, 04:51 PM | #12 | |
Rep 1,915
I do understand where you're coming from, but I think frequent oil changes are the best car insurance, second to none. |
Seattlesquash915.50 |
05-30-2018, 06:03 PM | #13 | ||
483
Rep 317
On my X5 35d i usually replace at 7500k miles or 6mo. My reasons, too many. Concur |
05-30-2018, 07:57 PM | #14 |
Rep 272
Do you consider LL01 to be critical? I run Mobil 1 5W50 in my sports car and the engines get great UOAs with it. I just wonder if the lack of LL01 for Mobil 1 by BMW is a business tantrum between the companies.
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) |
05-30-2018, 08:29 PM | #15 | |
483
Rep 317
Ironically Mobil-1 0w-40 European Formula used to have LL01 when it was first introduced, but LL01 was later dropped in 2014 with no formula change, and now recently (2016) they've switched out Oil company, from Castrol to Shell, its probally who can provide the right oil formula for BMW for the least amount of cash looks like Castrol lost out this time around. |
05-30-2018, 09:35 PM | #16 |
Rep 2,388
You have 2015 35i - I thought BMW had 4 year free maintenance plan no? If I'm wrong then here's what you'll need:
1. 17 mm socket to remove and tighten the drain plug 3. 16 flute 86.4mm oil filter removal tool (3/8” RATCHET, 27MM SOCKET, OR 1-1/16” SOCKET): https://www.amazon.com/Motivx-Tools-...r+removal+tool 4. 7 quarts (or 6.5L) oil + filter (Mann/Mahle as Mr.47 posted above) https://www.amazon.com/Mann-Filter-H...ds=11427566327 or https://www.amazon.com/Hisenic-Filte...ox+387+d&psc=1 I won't be contributing to the endless oil brand and viscosity holy-war, but whatever oil you go with - stick to it, don't change oil brands every time. |
05-30-2018, 10:19 PM | #18 | |
Rep 211
Mercedes has theirs (MB-Approval 229.5 / 229.52). The car manufacturers who use their own specs (just like GM dexos) have a program where they take what they know about their products, performance characteristics, engine wear, failure modes, etc. and decide which additives (and concentrations of additives) prevent the most problems for their engines. This leads to less warranty costs on their part. (eg some engines need more wear additives, dispersants, EP additives, and so on). Other auto manufacturers simply stick with API, ILSAC, and ACEA specs - and if the oil meets these specs it'll be suitable for use in their vehicles. It should be noted that some manufacturers consider their oil spec approval process to be a nice revenue stream, charging oil companies "fees" for submitting tests for processing. Additionally, the "first-fill" battle will always rage. Your oil cap may say Castrol today, Mobil1 tomorrow, and Shell in-between. Getting your oil brand as a factory fill, having your logo on the oil cap, and being listed in the owner's manual as a recommended brand are all very attractive benefits for oil manufacturers...thus they pay heavily for the privilege (ie severely discounted factory oil supplies for production fills, marketing co-ops, and so on). So, the real deal? Use what keeps your vehicle protected, your warranty in place (if applicable), the brands you prefer, and keep rolling! FWIW I use Liqui Moly Leichtlauf 5W40 in our Euro cars.
2014 X5 x35 F15
05-31-2018, 08:15 AM | #19 |
Rep 451
Our maintenance just expired and I'll be doing my first oil change on the wifes 35i x5. Plus/coils as well since she's at 55k miles. I checked the maint schedule and looks like a tranny flush is about due as well. Any good DIY's for maintenance on this one? I have a n54 335i that i've taken apart 1,000 times. Any "gotchas" on this motor/chassis?
05-31-2018, 10:42 AM | #20 | |
Rep 2,388
05-31-2018, 12:02 PM | #21 | |
Rep 1,497
That is correct...thanks
