03-23-2017, 03:43 PM | #221 | |
Rep 8,364
View post on imgur.com NGHB: View post on imgur.com |
03-22-2018, 04:45 PM | #222 |
Rep 120
Hey guys, so I just coded GFHB and when driving around in regular low beam mode, I feel like that my lights are lighting up people’s rear license plate more than normal. Has anyone else noticed this? I don’t have a good way to follow someone else at night to get feedback if they are too high or not.
03-23-2018, 12:00 AM | #223 | |
Rep 8,364
03-23-2018, 07:46 AM | #224 |
Rep 272
Any changes to the coding for 2018 F15 or do the Jan 2016 PDF instructions still work?
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) |
03-23-2018, 10:41 AM | #225 |
Rep 120
Sorry, I should have clarified a bit. When I drive around town in the dark on regular low beam mode, it seems like the low beams are aimed higher than before I coded the GFHB. I haven’t even had a chance yet to test the GFHB yet.
03-23-2018, 02:18 PM | #226 |
Rep 5,066
I need someone to remotely code this
03-23-2018, 06:16 PM | #227 |
Rep 8,364
Interesting. Most people complain that lights seem lower than from factory. It is actually designed for drivers side to be lower so as to not glare opposing traffic.
04-02-2018, 03:38 PM | #228 |
Rep 152
Me too... can someone remote code this only? i have Bimmercode App and got all the coding I need done except for this one.
Jeff
04-04-2018, 12:55 AM | #229 |
Rep 8,364
It can be done on own with E-sys or Bimmercode. It is the most work doing on own with Bimmercode. With E-sys, there are scripts written to quickly apply all necessary changes.
06-25-2018, 02:20 AM | #231 |
Rep 8,364
06-26-2018, 06:33 PM | #232 | |
Rep 25
After doing fdl encoding also according to the instructions. The distribution of light works, but it is completely incorrect ( |
06-26-2018, 10:59 PM | #234 |
Rep 13
I realize this has been going on for a few years now but if I'm driving a 2018 X5 with Adaptive Full LED lights and Assistant High Beam.. am I getting anti-dazzle or do I still ned to code it?
I'm driving X5 50i, M-Sport with Exec tier. Just picked it up a couple of weeks ago... Also, I have Bimmercode so if coding is needed on my F15, can someone post a link to the thread with the correct codings? Thanks very much! Last edited by masterfung; 06-26-2018 at 11:19 PM.. |
06-26-2018, 11:50 PM | #235 | |
Rep 8,364
06-27-2018, 04:56 PM | #237 |
Rep 25
encoded icm, nothing has changed (
in parameter LUT_FLC_FORWARDLIGHTING_Y there is no value F015_mit_AFS (9C 9C 9C), but even if you enter the values "9c 9c 9c", the lights still do not work correctly on high beams |
06-27-2018, 09:24 PM | #238 |
Rep 8,364
06-28-2018, 01:22 AM | #239 |
Rep 25
Please tell me why the distribution of high light rays does not work correctly?
Maybe because of low firmware? (52.3) Did everything according to the instructions, deleted 5ap, 8s4, then "code" bdc, kafas, icm, lhm, tms. Then I changed 16 functions according to the instructions. Errors erased. High beams work, but tonnel is not made either for passing cars or for oncoming vehicles ( for oncoming cars, the left-hand headlight diminishes its brightness, but the toner does not move. The right headlight chaotically moves its rays, blinding the passing cars. And the tonnel is formed for 1-3 seconds at a time when the passing car disappears from the visibility of the kafas camera. |
07-02-2018, 11:03 PM | #241 | |
Rep 8,364
Have you run analysis on your firmware level to check if more settings are different in LHM? |
12-10-2018, 08:22 AM | #242 |
Rep 272
Anyone successfully do the anti-dazzle coding -- NGHB and VLD -- on a 2018?
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) Last edited by Duke I; 12-10-2018 at 08:36 AM.. |
