07-04-2022, 09:40 PM | #23 |
Rep 939
My pump failed at a little over 40k miles.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
07-06-2022, 06:04 PM | #24 |
Rep 1,353
Interesting. Would like to see how it looks like.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
07-06-2022, 06:20 PM | #25 |
Rep 939
It was trashed. For a few months before I would smell some coolant when it's parked in the garage. Then she was in a parking lot right down the street and it dumped all the coolant. Brought it home and was putting water in it and water was pouring out of the pump area. The shop said it destroyed, I think the bearing failed.
07-08-2022, 10:34 PM | #26 | |
Rep 1,353
I spent total of 9h straight without removing the fan and radiator.
09-18-2022, 07:44 PM | #27 |
Rep 271
SaNGRia very interesting that you were able to drive the car hard while there was a warning. Last October or November, I went out to get lunch and while waiting in line to get gas, the cluster showed a warning about driving less aggressively to allow the car to cool down. Even then, my car entered limp mode and I was not able to put any power down whatsoever. I usually don't give the F85 in the northeast winters and used my e39m5 as the beater (it's already rusting, which is why I have reservations about driving a nice car in the salt) and my plan was to get the F85 on the lift in the spring. Spring came, I got busy with life and only just put the car up on the lift last night. You're right....it's very tight in there and bit daunting. How was the refilling/bleeding process once you got everything back together? I looked at the TIS and they had a video showing a fancy vacuum system to pull a vacuum and then flow coolant in. Needless to say, I don't have that.
BTW, my F85 is a '16 with 40k miles. |
09-18-2022, 07:49 PM | #28 | |
Rep 1,353
But anyhow, i havent done any fancy vacumming like it was mentioned on TIS. I also read that as well. Instead, i filled the reservoir with the BMW coolant then while the cap is off i turned on Electric coolant pumps like 3 times to cycle the coolant. And i added as it needed. Since then i am good and 0 issue.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 12-19-2022 at 04:51 PM.. |
ekological266.00 thowell3.00 |
11-28-2022, 10:19 AM | #29 |
Rep 14
12-11-2022, 01:37 PM | #30 |
Auto Lover
14
Rep 17
[QUOTE=ekological;27818918]Glad you found the issue! But man, at 34k miles and 3-4 years old, that corrosion looks scary! People laugh when I still have my '02 M5 beater to drive in the winter. It wasn't worth it to me to drive my new to me '16 X5M all year long starting two years ago when I purchased it.[/QUOTE
Exactly, shopping and looking at the spring, after the Wi. winter is over, to buy. But my daily drivers, '17 Cts Vsport, 2001 Prowler spend the winters in the garage as will the X5m. |
