12-29-2023, 05:08 PM | #1 |
Rep 499
N63TU Injector replacement
Well, looks like at 125k miles my 2016 X5 50i needs new injectors. I’m getting “bank 2 lean” when I give it a healthy amount of throttle.
For those of you who have replaced your injectors, any special tips or tricks? Anything I should look out for? Special tools needed? Possibly an “injector puller” I’ve seen? I know the injector compensation numbers will have to be put in the ECM. . |
12-31-2023, 11:56 PM | #2 |
Rep 7,167
You sure it’s the injector and not the HPFP?
01-01-2024, 06:01 AM | #4 |
Rep 499
01-01-2024, 06:03 AM | #5 |
Rep 499
Is there a way to test the fuel pump before replacing it?
I did get a “bank 2 lean wide variation” code in addition to just bank 2 lean…would that indicate fuel pump instead? |
01-01-2024, 08:46 AM | #7 |
Rep 499
Agreed…checked using smoke and didn’t find anything. I figure at 125k miles it’d be good to refresh the fuel system, although it sucks to be spending even MORE money right after Christmas lol
01-01-2024, 10:22 AM | #8 |
Rep 818
Drives: BMW X5 XDrive35i
if you’re able to datalog or watch rail pressure under WOT and it crashes, that would tell you it’s the high pressure fuel pump.
01-01-2024, 12:42 PM | #9 | |
Rep 499
On BimmerLink I was able to find “filtered rail pressure” but it isn’t separated into bank 1 and bank 2. Any suggestions as to what to search for? |
sukhk5272207.00 |
01-01-2024, 02:45 PM | #10 |
Rep 818
I’d have to search myself on BimmerLink tbh. I know on BM3 and MHD we get requested and actual rail pressure measuring blocks. I’ll see what I can dig up on Google.
tfunk88204.00 |
01-02-2024, 08:39 AM | #14 |
Rep 818
injectors are very possible. I believe ISTA can run an injector test but I’m not 100% certain.
