10-24-2019, 06:02 PM | #1 |
Rep 115
X6 F16 Low Windshield Washer Fluid Fixed!!
I just wanted to share my experiance with fellow forum members.. When I purchased my X6 the Low windshield washer fluid light kept coming on at startup despite being full of fluid.. One dealership informed me that it was the washer tank and that the sensor is built into the tank.. And that it was a costly repair as the front fender had to come off the car.. Not happy with that answer I went to another dealership and spoke with a mechanic on break.. He told me to push out all of the fluid that was in the tank until no more came out.. He then advised me to fill it up with Prestone Bug Wash.... After I filled it up I drove the car for 5 minutes and would you believe the light went out and hasn't come on since.. The Prestone Bug Wash must have cleaned the residue off of the sensor.. I hope this helps other forum members.
10-24-2019, 06:09 PM | #2 |
Rep 2,517
That is a known issue man, actually they don't recommend anything from Prestone or any different color than blue. It was also a class action lawsuit against rain-x, their fluid would kill the sensor eventually. I had this issue and switched to the OEM BMW concentrate, it is still cheaper than any other windshield washer fluid and will never give you the low washer warning light.
10-24-2019, 07:02 PM | #3 | |
Rep 115
10-30-2019, 05:49 PM | #4 | |
Rep 7,164
10-30-2019, 10:49 PM | #5 |
Rep 2,517
Happens more often in the areas with colder climate, I used to live in Tahoe and when I got my X5 this problem pop up as soon as the temps dropped below 25 and I used some Prestone washer. Brought it to the dealer, they told me not to use orange fluid. It was even discussed here
https://f15.bimmerpost.com/forums/sh....php?t=1084945 https://f15.bimmerpost.com/forums/sh....php?t=1505585 And if you google this issue you will see a lot of threads about it. |
10-31-2019, 09:12 PM | #6 | |
Rep 7,164
10-31-2019, 09:14 PM | #7 |
Rep 2,517
I think blue color, and it does sound absolutely ridiculous. I just switch to OEM concentrate since its actually cheaper and you can mix it according to the conditions.
11-11-2019, 12:44 PM | #8 | |
BMW Fanboi
Rep 4
we bought ours used this summer and the windshield sprayers barely work. Headlights are fine. I don't know what fluid is in it but guessing prev. owner may have used rain-x. Thinking of running it dry, trying to run a bunch of bug remover through the system then switching to blue? |
11-11-2019, 12:59 PM | #9 | |
Rep 115
