12-30-2015, 10:45 AM | #1 |
Rep 5,066
DIY - X5 Badge/Emblem Swap
Here is my step by step pictures of swapping out the OEM chrome emblem to gloss black emblem I got from iND. iND uses OEM emblems and paints it to your liking.
Factory emblem... Items used: 70% Isopropyl Rubbing Alcohol, Microfiber cloth, automotive exterior tape or painters tape, dental floss or thin fishing line. Optional: hair drier to help remove the adhesives easier. Mark the location of the factory emblem by creating a frame around it with painters tape. Work the emblem with the dental floss in a sawing motion slowly.. you will more than likely break a few strings but keep working it and have patience. If your car is fairly new, the adhesives should come off easily... I just used my fingers and rubbed the adhesives and peeled them off. I used a little of the rubbing alcohol to help with the removal. After completely removing the adhesives, I used the rubbing alcohol to wipe the area down clean which helps with the bonding of the new badges. The X! All you do now is just line up the emblem from the left and right side of the frame and press firmly.
13
JustChris17605.50 sweeper631.50 gqgambler722.00 OFFWHITEX5325.50 shezi0157.00 fsquared25.50 jmack1231302.00 macharleston0.00 |
12-30-2015, 10:55 AM | #3 |
Rep 1,247
Nicely done! I like the look.
My current X6 is the first car I debadged, and I used dental floss as well. The adhesive gave me a bit of a hard time, but I used bug/tar remover to solve that problem. Your idea to use rubbing alcohol is genius. I have a whole bottle of bug/tar remover that I will probably never use again since I haven't been straying too far from the NYC area like I did when I was younger, lol
Too smart for my own good...
12-30-2015, 11:09 AM | #5 |
Rep 194
Drives: 2024 X5 50e
Personally I'm not a fan of debadging, but I really like your black gloss emblem, especially with the the contrast against your space grey.
Former: 2020 Volvo XC60, 2018 Volvo XC90 T8, 2016 X5 40e, Lexus RX 450h, Acura MDX
First: 1963 Chevy Corvair (in 1984) |
12-30-2015, 11:19 AM | #6 |
Rep 1,547
Nice work man. Now it's time to replace that roundel with a black one.
12-30-2015, 01:04 PM | #10 |
Rep 5,066
Thanks guys! I got the emblem from iND http://ind-distribution.com
You can purchase a cheaper X5 emblem from eBay / amazon but these are for E70 X5 and the emblems are bigger. I originally got one from amazon and when I compared it with the oem emblem, the size was significant and the way the F15 trunk is designed the emblem doesn't fit flush enough for me. After a few times of debating on other options ( plastic-dip and painting it myself ) I decided to just pay up for the iND version and I am a satisfied customer.
12-30-2015, 02:20 PM | #13 |
Rep 1,181
Good write-up as usual @kzang.
Heat gun is your friend when it comes to debadging. Literally hit the emblem with 5-10secs from the gun and the floss or fishing line will slice through like a hot knife through butta. Makes residue removal a breeze as well.
12-30-2015, 05:52 PM | #14 | |
Rep 41
12-31-2015, 09:15 AM | #18 | |
Rep 5,066
07-10-2016, 01:01 PM | #20 |
<3 Flat Four
217
Rep 754
u can use fishing line if u have some, so it doesnt snap on u. and if ur car is fairly new u should be able to just peel off the emblems instead of cutting the adhesive.
2011 335is Le Mans Blue
07-10-2016, 04:22 PM | #21 |
Rep 171
07-10-2016, 04:28 PM | #22 |
Rep 7,063
Don't cheap out on floss boys. "Reach" for the best
lol I'm bored today
