      09-26-2023, 09:34 PM   #1
Djhumvee
Drives: 2017 X5 50i
Tony's Upgraded driveshaft install (2017 50i)
Installed the upgraded driveshaft from Tony tonight. I couldn't slip the new one in without removing the u-joint on the front differential end of the shaft. If the exhaust/downpipe was off I would have had way more room. This was on a f15 though, maybe the f85 has a little more clearance, the exhaust may be more out of the way on the f85? Anyway here's the videos, first time making a video so it probably sucks lol. Also I tried just taking 1 video but every time my screen shut off it wouldn't let me continue recording I had to start a new video.
https://www.youtube.com/watch?v=COXecFMkvAM
https://www.youtube.com/watch?v=Zj5kcMrx0vY
https://www.youtube.com/watch?v=QrkMOhTp_Wo
tfunk88198.00
      09-26-2023, 10:49 PM   #2
Djhumvee
Drives: 2017 X5 50i
I talked to Tony and watched his install video, it does appear it will slip in without taking the u joint apart, but I tried it several times just like he did in the video and for whatever reason I could not for the life of me get it to go in like that.
      09-27-2023, 03:30 AM   #3
Djhumvee
Drives: 2017 X5 50i
So I talked to Tony a little more, he thinks that the motor mounts could be worn out causing the motor to sit lower, which would give less clearance for the shaft to slip in-between the metal bracket and differential.
sukhk5272178.50
      09-27-2023, 10:36 AM   #4
tlaspec
Drives: f15
Appreciate your update and install video, wondering how many miles you had on the original shaft and if you noticed any wear or looseness. Did you just change the shaft as a preventative measure. Dissapointing that bmw cant make a reliable shaft after the recalls on the E70s.
      09-27-2023, 11:29 AM   #5
Djhumvee
Drives: 2017 X5 50i
Truck has around 94k miles on it, I've had it since around 70k miles and Ive never replaced it. The joints were tight but I could wobble it where it goes into the t-case.the new one feels tighter where it enters the t-case. I can get a little wobble out of it but it isn't the shaft its the t-case and it's very minimal. So yeah I only changed it as a preventative measure since I plan on adding some parts and a tune to get above the f85 stock power.
HJ478.00
tfunk88198.00
      09-28-2023, 04:36 AM   #6
dentprotony@gmail.com
Drives: 2018 f85
Yep, its a good idea to replace as a preventative, because if the stock shaft pops it will create havoc underneath your f15, causing damage to transmission and possibly an oil pan, will make your day go south quick and cause thousands in damage
sukhk5272178.50
