04-17-2024, 07:13 AM | #1 |
Rep 134
NBT -> NBT EVO Parts Needed + Coding
Need some help guys.... Doing a NBT -> NBT EVO on a X5 I will be giving to my son. Need help on the parts list. I do not care about factory navigation, etc.
So Far I have: NBT EVO HW 3.2 Things I need: BMW CID Display Converter cable Wifi Antenna What am I missing? What else do I need to make this work? Can I install and code directly from the vehicle, or will that trigger any protection mode? If it does, any recommendations on bench coding? Thanks in advance! Last edited by Scottycs19; 04-17-2024 at 07:27 AM.. |
04-17-2024, 09:31 AM | #2 |
Rep 2,513
https://f15.bimmerpost.com/forums/sh....php?t=1593428
This thread got all information you need. |
04-17-2024, 10:20 AM | #3 | |
Rep 134
I already went through that thread, doesn't really give all the information like.
Do I need a Can Filter? Can I code in car? Even if it goes into component protection? Or does it need a bench flash? Can I code with Protool? Do I need Esys? Do I need a OABR harness? or can I communicate through OBD? ETC. Quote:
04-17-2024, 11:24 AM | #4 | |
Rep 2,513
Yes you usually code in car. If you do everything properly it should not go into the protection. If it does you will need set of FSC codes to remove it. You do need E-Sys. Ask OP of that thread, he is very helpful and shared information before. |
04-17-2024, 12:12 PM | #6 |
Rep 134
Just decided to go with Code My Bimmer to reflash the unit/remote coding as well as provide the necessary cables. No headaches on my end..
NBT EVO to APIX1 cable Wifi cable OABR cable NBT EVO Unit $350 Flash/Coding/Cables $279 $629.....not bad |
04-24-2024, 03:33 PM | #7 |
Rep 627
Drives: X5 F15 M package
where did you find the eco unit for $350? Scottycs19
