      01-23-2024, 11:02 PM   #1
andyboioi
Drives: 2015 X5M F85
New Member w/ issues x5m
Hi y’all,
I just completed replacing my fuel, injectors, spark plugs, ignition coils, my battery, my fuel pump relay, the fuel pump fuse.
I would like to say that the car was disconnected “engine & battery” for about 4 weeks. The scanner did say “replace battery after reconnecting it” Then I went ahead and finished the job just lastnight.
It turns over and after 10 seconds, it starts to go in and out w/ a different in idling.. “no leaks, gas, or gas leaks.
I did a fresh diagnostic a new code
popped up 11AC02, it did mention possible solutions low gas? I have a 100 miles left in the tank
I’m scared to let it run any longer lol
Any suggestions?? I’m sure somebody has done what I’ve done and experienced or have suggestions on what I should do
      01-24-2024, 04:46 PM   #2
Cbozz
Cbozz's Avatar
Drives: M3
Originally Posted by andyboioi View Post
Hi y’all,
Its your HPFP error for fuel pressure too low.
Maybe after all that your replaced it is drained.
I would clear the codes and try again..it may be your HPFP that has an issue..
      01-25-2024, 12:10 PM   #3
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
As mentioned, HPFP may be your issue. Have you taken it to an indy shop and have them run diagnostics?
