11-30-2016, 11:31 AM | #23 | |
Rep 18,717
The 10mm is cutting it close, since there is a bevel inside the wheel where it sits on the hub. So with 10mm spacer, the wheel may not sit properly on the hub, only about 2-3mm on the hub. I don't think it will be safe enough with the weight of the car. While the 12/13/15mm spacers, it has the hubcentric rings on it, where it won't clear the hub shoulder where it is over 15mm tall.
Violator4587.50 |
11-30-2016, 05:00 PM | #25 | |
Rep 192
11-30-2016, 05:09 PM | #26 |
Rep 18,717
You can't since your car is built after the date that I mentioned.
12-01-2016, 09:27 AM | #27 | |
Rep 18,717
For your friends, have you asked them to take off the wheels again to check if it break or not? I mean, I have no problem selling them, but if it break, I won't replace them for free like the last time it happened. I got 1 forum reader, not sure if he is a member or not, bought a set of 15mm for his '16 X5 and broke it. Then blame me for it even though there are notes on the product description on my website and filed a dispute after I explained to him everything. And the bank, of course, favors the consumer. Even H&R stated, it is customer responsibility to check the hub clearance before install. They won't warranty them if it a damage caused by customer.
