      06-22-2018, 04:09 PM   #23
Arrived!
Originally Posted by Doanster View Post
Replied. Deal is still available. Note that it may take up to two weeks as there is limited stock on hand.
Blackvue DR750S-2CH arrived! I’ll install the set over the weekend.
Doanster626.50
yewlock697.50
      06-23-2018, 12:32 AM   #24
Doanster
Doanster's Avatar
627
Nice! No time to install this weekend for me. Well, at least not the rear cam. Front cam should be 10mins for my EV (not the F15).
      06-26-2018, 11:43 AM   #25
aracka
Drives: 2015 X5 X50i
I installed mine this past weekend! it works great....but i feel like the parking mode isn't recording for long if at all. had the switches set to 12V and Infinity on the power magic pro. i even tried to nudge my car a bit and it doesnt seem to have any recordings....i think i still have to tinker with it to make sure i dont have something setup wrong here
2015 X5 5.0 | Space Gray | Driver's Assistance + | Luxury Pkg | Executive Pkg | Lighting Pkg | ACC | DHP | Nightvision | Multi-Contour
      06-26-2018, 07:18 PM   #26
britelzg
Drives: 2018 X5 35i
I'm going to have the professional do it, which costs CAD $800 (the camera and labor). But my dealer told me installing 3rd party electric device will void the warranty. Also I'm leasing the X5. Do I need to uninstall it before returning?
      06-26-2018, 07:44 PM   #27
Voiding a warranty is absurd, I’d find a new dealer SA right away.
      06-26-2018, 10:32 PM   #28
TOPEC
<3 Flat Four
Drives: 335is LM Blue
U have to tinker with the settings, but pretty much on the power magic pro set it to a) cut off at less than 11.8V and b) timer to stay on to be 8+ hrs for when u park the car at work. on the camera itself, u need to set c) parking mode sensitivity to max and d) motion detection to max. With these settings, it should make the camera record continuously unless the car is parked and not started for 10+ hrs. This also eliminates the possibility that a very light bump/tap from another car not triggering the camera to record. And remember, ull need a large memory card for all the continuous front/rear camera recording, i myself is using a samsung 850 evo 128GB micro sd card.
2011 335is Le Mans Blue
      07-01-2018, 06:15 PM   #29
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
Finally installed the dash cam. Followed Ben's instruction and very straight forward. The hardest part for me was to peel off the red protective tape.
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      07-02-2018, 06:01 PM   #30
yewlock
yewlock's Avatar
Drives: X5
I can not decide if I should get 750 or 900. I saw you got the 750. Any reason why not 900?
      07-02-2018, 06:09 PM   #31
I didn’t feel like I needed 4K resolution for a dashcam, plus the price of the 750 shipped couldn’t be beat anywhere.
So far, I’m very satisfied with my choice!
Installation is very simple, next I’ll add a direct power source from the rear view mirror or fuse box.
yewlock697.50
      07-03-2018, 08:23 AM   #32
aracka
agreed 750 is great quality
      07-13-2018, 02:29 PM   #33
ikheetleon
Netherlands
219
Drives: BMW X5 45e 2020
Anyone got any tips for getting from lower C column to trunk fuse box? (LHD with 3rd row seats). According to realoem, there should be a skrew in the right trunk trim part (the one where the 12V plug is in), but there is none. I did found a plastic skrew when removing the fusebox panel door. But I can't seem to get the bigger vertical panel (with 12V) removed. It seems stuck at the top near the normal seats.
      07-13-2018, 04:35 PM   #34
THATDONFC
Driver 🇦🇲
THATDONFC's Avatar
Drives: 2021 X5 M50i
If anyone is interested in getting a great deal/discount on Blackvue cameras, including the new 4K 900S, PM me. I am NOT selling them nor am making anything off this. Just trying to pass on a good deal. I cannot post details publicly. If this is in violation of forum rules, my apologies and the mods can delete.
Very interested in this deal. PM me the details please and thank you!
      07-14-2018, 02:16 PM   #35
Doanster
Doanster's Avatar
627
PM sent. Hope the rest of you got your cams and have them up and running.
aracka60.00
      07-14-2018, 11:21 PM   #36
Silververtu
231
It's a great deal if you are OK to wait for a few weeks. I ended up buying mine somewhere else.
2019 Cayenne Turbo
      07-16-2018, 12:50 PM   #37
Doanster
Doanster's Avatar
627
Yep. I've been letting people know that in PMs. They are batch-ordered and need to clear Customs, etc. Def not a normal web order situation. Great deal if not an urgent need...
      07-19-2018, 11:14 AM   #38
Galun
Drives: E60 M5, F15 X5d
If the deal is still available, please PM. Thanks.
      07-19-2018, 03:03 PM   #39
dagwoodnil
Drives: 2014 X5 35d, 2017 M2 MGM MT
2014 BMW X5 35d  [0.00]
2009 BMW Z4 35i  [0.00]
Can you please sent me the details?
Thanks!
      07-20-2018, 08:47 PM   #40
Doanster
Doanster's Avatar
627
Thanks!
PM'd
      07-20-2018, 09:46 PM   #41
yewlock
yewlock's Avatar
Drives: X5
Just arrived
menelaos1226.00
Violator4587.50
      07-20-2018, 09:48 PM   #42
yewlock
yewlock's Avatar
Drives: X5
Thanks Doanster, Violator for recommendation
Violator4587.50
Doanster626.50
      07-21-2018, 01:55 AM   #43
ikheetleon
Netherlands
219
If anyone is looking for a spot to place an additional dashcam battery (Cellink/Powermagic/etc), you might want to look underneath the storage tray in the boot. It’s directly under the rear fusebox and to get there you only need to remove 3 plastic plugs. Make sure to cover your battery with some heat resistant but soft material to avoid unwanted noise. I’ve just placed my Lukas LK-570 in that spot and hooked it up to the rear fusebox (12v outlet in the trunk fuse).
      07-21-2018, 03:27 AM   #44
Galun
Please pm details. Thanks,
