12-21-2019, 12:26 PM | #47 |
Rep 1,343
Yeah, I was going to get it too, but I didn't feel like spending almost 50 dollars Canadian on it lol
12-21-2019, 02:14 PM | #48 | |
Rep 289
https://play.google.com/store/apps/d...obdmaven&hl=en I mentioned this in post #4 in this thread
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr Last edited by ems328i; 12-21-2019 at 02:22 PM.. |
Russmov1328.00 |
12-21-2019, 07:57 PM | #49 |
231
Rep 369
Same here, little bit to expensive but luckily for all the coding I've done I never had to clear any codes, I never had any
Current
Russmov1328.00 |
01-27-2020, 10:24 PM | #50 |
Rep 1
Thanks!
Thanks for all of the info on this exhaust mod. I've been perplexed as to why I have a F16 with dual exhaust tips and exhaust only comes out of one side. Other posts have had much more invasive procedures in order to get the flap to stay open. The posts on this thread were perfect and keeps the car as stock as possible. Tomorrow I will be downloading the Bimmerlink app and pair it with my VeePeak ODB module and remove the fuse. (Provided I can find it) Can't wait to see how much of a difference it makes.
01-29-2020, 12:53 PM | #51 | |
Rep 12
My safe way of opening my flaps
I realized a few things in this process. I always thought there was a flap on the right (passenger) and left (driver) side. When I went underneath the car, there was only a flap on the right (passenger) side. I'm guessing there might be a flap in the muffler I n any case, I wanted a simple yet effect way of getting the exhausts open w/o voiding my warranty. Although my dealership knows that I tuned my f15 to about 400hp (I used RaceChip), as long as I take it off they're fine with it. But when it comes to the exhaust it's not a simple plug and play. In any case, I wanted any restriction gone. I know on start up the driver side exhaust is usually loud then it mutes after about 45 seconds or so depending on how cold it is. When its -40C both exhausts open but it wasn't the case today. Before turning on the car, I located the 146 fuse (you can find a picture of it of the quote I have on top) and got the right tool (could be literally any tool as long as it can pull the fuse) I tested it to make sure it works. Next I tackled the passenger exhaust where the flap actuator is. I wanted an OEM fix, aka less work I have to do on the car, the better. I found the C ring that everyone was talking about; I uploaded a picture I found online but its exactly the same found in my car. I thought I could've have moved the C ring upwards to open the exhaust whilst everything is connected and then pull the fuse but 1. it's really not budging and I didn't want to break anything 2. If I pulled the fuse the driver side flap would remain closed so essentially useless. I pulled the C ring in literally less than 10 seconds with same tool as I used to pull the fuse. TBH I was dying but it happened, I turned the "knob" closest to the exhaust (or the right side of the picture uploaded) upwards and that opened the flap. I kept turning it until I couldn't anymore that means I won't accidentally close the flap if I kept turning it. But beware, due to the cold, the knob could be stuck, so give it some tug but don't overdo it, use WD-40 if you have to. I turned on my car, immediately pulled the fuse and both exhausts were open. Now to tackle the question of how to keep the flap open, as I said I wanted to simplest fix, so no wires or anything. Because its metal, I used glue/superglue, although scary, it's just metal and you break the glue pretty easily. So now when I send my car for service, they won't see anything out of the ordinary other than the C ring being out of the car. I don't think they'll bother looking for it everytime. No check engine light thus far. Last edited by Khedr; 01-29-2020 at 12:56 PM.. Reason: upload extra picture |
01-29-2020, 02:06 PM | #52 | |
Rep 289
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
01-29-2020, 02:10 PM | #53 | ||
Rep 12
Pretty much if you want the "free" way of doing it then my way would work best. But thanks for the feedback! |
01-30-2020, 08:10 PM | #54 | |||
Rep 12
01-30-2020, 11:06 PM | #55 |
<3 Flat Four
217
Rep 754
there is no flap in the drivers side. there is only 1 flap on the 35i and it is located on the passenger side.
2011 335is Le Mans Blue
01-31-2020, 12:27 AM | #56 |
Rep 289
This. Pulling the second fuse is what is likely giving you the error....
01-31-2020, 01:16 PM | #59 |
Rep 289
Delete
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr Last edited by ems328i; 01-31-2020 at 01:22 PM.. |
01-31-2020, 01:21 PM | #60 | |
Rep 289
If you have 'forced' open the valve using an app and OBD dongle then it will stay open as long as you want it to (until you shut off the engine) so you have plenty of time to pull the fuse. If you don't use an app, then the valve will only open at high rpm so you then need to manually force it open as described earlier in this thread....but make sure the exhaust is cold first!
07-04-2020, 09:56 AM | #61 |
110
Rep 385
Could you start the car and quickly put something in the tailpipe that Would prevent the flap from closing and then pull the fuse? Would it then stay open after you pull out what kept the valve propped open?
Asking for a friend Lol |
06-26-2023, 03:11 PM | #62 |
Rep 5
Let’s revive this thread based on F85 models. X5 M have a left and right actuator motor, and with the Carly app, only the paasenger side actuator opens. I verified the drivers side actuator motor does work when I switched it to the oassenger side?
Does anyone have any idea why this is? Is the left side actuator only operable at wide-open throttle? |
