09-20-2019, 09:38 AM | #1 |
Rep 121
Speed Limit Info - Retrofit - 2016 X5 ??
Hi,
looking at retrofitting the SLI info on an X5 - I've the latest version of maps but cant get any info out of BMW to find out if it has SLI information .. but presume it must have ?? Been lloking at the retrofit emulators but don't want to buy one if I'm wasting my time .. I have a coder btw Any help or guidance much appreciated .. |
09-20-2019, 09:44 AM | #2 | |
Rep 674
09-20-2019, 09:46 AM | #3 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Freude am Fahren.
10-03-2019, 03:19 PM | #5 |
Rep 121
Guys
I've fitted the emulator - all good But I don't seem to have the options available to me on the coding app? I'm using the BimmerCode app but it doesn't seem to have any options to code the speed limit either in HU_NBT or in Kombi Any help appreciated |
10-03-2019, 06:35 PM | #8 |
Rep 2,513
Can't get it on mac, you need a VM to run it on Apple computer. Please use search.
https://f15.bimmerpost.com/forums/sh....php?t=1033991 |
08-22-2022, 06:22 PM | #9 |
Rep 270
It's been a while but came across this post and wanted to share come coding tips. I got an emulator and the coding that accompanied it is quite good and extensive (courtesy of Bimmer8.com). The easiest is to FA code to your car but if you need to FLD code it, here are some thing to look for (not all are needed in every car model).
F-Series - KOMBI Ecu ANZEIGE_NPI = aktiv KI_PIA_SPEED_LIMIT = aktiv SPEED_LIMIT = aktiv SPEED_LIMIT_GENERATION = sli_gen_2_npi RCOG_TRSG_APPL = aktiv RCOG_TRSG_TIMEOUT = aktiv G-Series KOMBI Ecu ADDITIONAL_SIGN_ENABLE = aktiv ANZEIGE_NPI = aktiv CB_TACHOZEIGERBAND = aktiv CB_SLI_NPI = aktiv PIA_SLI_NPI = aktiv RCOG_TRSG_APPL = aktiv (* See Notice below) RCOG_TRSG_TIMEOUT = aktiv (* See Notice below) SLI_PERMANENT_ENABLE = aktiv SPEED_LIMIT_ENABLE = aktiv TACHOZEIGERBAND_ENABLE = aktiv NO_PASSING_ENABLE = aktiv SPEED_LIMIT_UNIT_ENABLE = Wert_02( If you don't want to display speed unit kmh or mph, please set Wert_0 ) F / G Series - KOMBI Ecu If your vehicle has a HUD (Head-Up Display) do these. Just ignore if you don't have a HUD. HUD_NPI_ENABLE = aktiv HUD_PIA_SPEED_LIM = aktiv HUD_SPEED_LIMIT_ENABLE = aktiv HUD_SLI_ENABLE = aktiv PIA_HUD_SLI = aktiv PIA_HUD_SLI_NPI = aktiv PIA_HUD_SLI_PORTIERUNG = aktiv PIA_HUD_VSLI = aktiv Coding to be modified for HU_NBT or HU_NBT2 ECUs SPEEDLIMIT_INFO = aktiv SLI_NAVI_DISPLAY = nicht_aktiv Check "Speed Limit Information" in the Instrument cluster settings for the HUD - check box as needed. |
