10-06-2014, 10:49 AM | #199 |
Rep 40,951
I have PM'd you Token solution info.
10-06-2014, 10:59 AM | #200 |
Rep 193
10-06-2014, 03:41 PM | #202 |
Rep 1,760
Opasha, ebay seller is amazing, ordered friday night (I think) or Saturday, received the cable today. Only thing missing is my new X5.
My only problem is that Mega... I hit download, I leave and come back I can't see where it saved the file. It's frustrating.
2024 X3 m40i
10-06-2014, 03:57 PM | #203 | ||
Rep 3,990
You are most welcome . Quote:
I think this is usually the same folder where all your Downloads are located. You can just search for this location. Or, you can right click in your downloads window in your firefox, google chrome, or IE history (or safari, but not sure how Mac works) and right click to open file location.
10-06-2014, 04:00 PM | #204 | |
Rep 1,760
I tried 4 times, no luck because I am not here when it completes. I will check again online to see how it works.
2024 X3 m40i
10-06-2014, 04:03 PM | #205 | |
Rep 3,990
That might help. Try using Chrome to download it and make sure you know where Chrome is downloading it to. Supposedly, this works as well: http://megadownloaderapp.blogspot.co...s-english.html Also, as I suggested earlier you can search for the file that was downloaded: https://support.mozilla.org/en-US/questions/975925
10-06-2014, 04:42 PM | #206 | |
Rep 193
My mistake, sorry for confusion. Indeed Shawnsheridan really hoped me!!! Thanx a loOot Shawnsheridan, he guided me through all process of installation!!! And I can tell now that I made connection with the car!!! It is already progress for me!!! I was excited doing this! But still have some problems!!! May be you, Shawnsheridan or somebody else can help me, otherwise for me it is difficult!!!:roll eyes: Have following problem: Wanted to do following change in the car(as per instruction from first page) 4) Auto Start Stop OFF by Default in Comfort Mode: Comfort mode should remember your last setting when you turn off your car, but I hate this feature (especially after reading a while back how it may create more wear and tear on the engine in city driving with lots of lights/stop signs). I also don't use it in Eco-Pro but this code won't turn it off in Eco-Pro mode because it's supposed to maximize fuel efficiency by turning off the engine. It is located in BDC_Body>3026: TC_MSA_DEFAULT_OFF: nicht_aktiv to aktiv However something I did wrong as was not able to find folder "BDC_Body>3026" |
10-06-2014, 04:49 PM | #207 |
Rep 193
I did connection with the car(as described in instruction) than went to "Expert mode" and pressed button "coding".
But as mentioned was not able to find folder"BDC_Body>3026", where I should do coding for auto start/stop. Any idea what I did wrong??? |
10-06-2014, 04:52 PM | #208 | |
Rep 208
Read FA -> Right click on FA and Activate -> Read ECU then you will see all the ECU in the left below box. There you will have BDC_BODY. |
10-06-2014, 04:53 PM | #209 | |
Rep 1,760
Thanks, I totally forgot I had the Mega add-on, which was required for Firefox a while ago whenever you wanted to download a large file, and I noticed I chose Desktop as my default Mega folder. http://i.gyazo.com/1d16c34072859079e3768265706d13a1.png I found them sitting there on desktop! LOL. That's not even my default download folder for my usual stuff.
2024 X3 m40i
10-06-2014, 04:54 PM | #210 |
Rep 1,760
Is there a code to make Sport mode default without having to select it every single time? Or can it be a profile setting?
2024 X3 m40i
10-06-2014, 04:55 PM | #211 | |
Rep 208
Right click on the FA on the top and click Activate FA. Last edited by Hang0ver; 10-06-2014 at 05:02 PM.. |
10-06-2014, 04:58 PM | #212 |
Rep 193
As well as would like to know if it is somehow possible to reset errors which are in the car???
Yesterday I tried to open tow hitch(it is fully electrically driven) and accidentally it touched stone border and went back. After this I had message that I have to go to dealer for check. I tried to operate it once more it just didn't work(red button was active all the time). After car stayed for a few hours I pressed it several times and tow hitch came out and again was not operational. I checked instruction manual and it says that it will work if certain conditions are met: low temperature(which is not the case) and if it touch mechanical parts(this was the case). So may be I can somehow reset errors in the system??? P.S. I made already an appointment with dealer, but it will be next week only and as I believe that it needs just reset thought that it can be possible to do somehow... |
10-06-2014, 05:00 PM | #213 | ||
Rep 193
I did not do activation of FA, so will do it tomorrow(as it is late already in my country)!!! |
10-06-2014, 05:01 PM | #214 | |
Rep 208
Hit external applications in the left . then click external applications again. then in the list, select the last line which is pretty long. Then click connect and then execute or something that runs and clears off... then disconnect.. not at my computer, if you can post picture, I can tell exactly. |
10-06-2014, 05:02 PM | #215 |
Rep 208
10-06-2014, 05:04 PM | #216 | |
Rep 193
10-06-2014, 05:07 PM | #218 |
Rep 208
10-06-2014, 05:16 PM | #219 |
Rep 193
As understood that after I made coding I need to confirm it by pressing coding verification???
Is it correct??? If I press this button system asks me PIN-this is the one which was sent with token??? |
10-06-2014, 06:09 PM | #220 | ||
Rep 3,990
Also, this is to the rest of the bimmerpost community: I understand that my OP is long and sometimes things can get confusing or missed. I have added the activation of FA in bold so you don't miss it. I take little things like this and try to make it easier to read. If anyone has any suggestions to better improve the OP instructions, feel free to let me know. I'm always happy to make it easier for everyone. However, I have included EVERYTHING you need to the best of my knowledge necessary for you to successfully setup and learn coding.
